Ive had a filter come off in the dunes. Forunatly it didnt mess anything up. But what i found was the filter pod i had was about 6 years old and the rubber has hardened vs a new filter. Bought new filters havent had a problem. Next i will try out the toomey 2 into 1 filter.
I follow you on instagram, i wanted something lower profile and didnt want to cut the brake line mounts. Although that probably doesnt matter so i just made my own.
Im in the process of doing a dc conversion to run leds. I also want to relocate the cdi, battery and rectifier. Would this be ok or will it not run right with the different components this close together?
Now I have another question. What did you do for dc conversion and battery? I just got the race tech electric 200watt dc stator kit. Now I'm just trying to figure out a battery.
Sent from my SM-N900P using Tapatalk
Cool cool, looks like you cut the stock brackets off. Did you have to weld a tab to off set the bolt from hitting the shock or just drill the hole as far over as possible?
