TNTS355
Everything posted by TNTS355
  1. Use RTV or yama bond. on the bottom side of the cap put the tube nut on to help hold it in. You will need a threaded tire stem for the other cap.
  2. take the rubber piece off of the guage that looks like a tire and the rubber piece out of the aluminum style nut.
  3. The brass piece stays on there. The aluminum nut I ground down to make it shorter. I drilled the end of the cap put the pressure gauage on and used silicone to seal it up. The air nipple, was a screw style (O'Reillys) that came in a two pack. The rubber freeze plugs have not been a problem, no leaks. I have held 6lbs in my motor for over 15 minutes, after I sealed up the leaks.
  4. Not to call you a liar but I have NEVER seen a hotrods Banshee 4mil 115 crank on Ebay for 325.00 Who is you buy it from so I can buy one?
  5. I think the freeze plugs at 1 3/8. The pipe for a stock 26mm is 1" pvc.
  6. I talked to him last nite, his coil ohm'ed out at .5.
  7. Glad to have you here and can now talk. You must have done a lot of reading.
  8. Here is a link to build your own leak tester. http://forums.everything2stroke.com/showthread.php?t=16162 I made my own out of pvc, tire valve and a slime pressure guage. If you need me to take a pic of it and send it to you I will. Apply 6psi, no more!
  9. I will still go with an air leak. Keep us posted.
  10. Sounds like you have an airleak. Did you do a leak test after replacing the topend? I know if sounds stupid but even after replacing reeds or boots I do it.
  11. come by in the evening after your done, you dont harvest at night.
  12. I know and I know Cam so its all goog. Cam is a good guy and likes to help. I meet him at LS, he is just a blunt kid of guy and speaks his mind and I like that.
  13. I didnt see it listed but if you have a three piece stator cover I would be interested if you part it out. I live in Arlington, Texas.
  14. you have my number just give me a call and I will guide you over the phone as much as I can. Make SURE you buy a Clymers manuel, its a really good investment if you are going to own a Banshee/
  15. Ask him where he got it or built it. A picture would be good so i would have something to work off of. If you dont mind pm it to me.
  16. LMAO!!!!!! I know what your talking about
  17. I have a set for a coolhead, dont know if they will fit a Vitos.
  18. Its a large thin block that is on top of your carbs, there will be wires leading into it. As far as a tester goes, I use a Fluke, but you might try a Craftsman. If you still cant get it running later you can give me a call. My number is listed on my profile.
  19. Myself and quaddad817 are thinking about building some typ of 12v light tree for the friendly dragging. I think the biggest problem will be finding 12v lights that are big enough for everyone to see.
  20. Did you loose a ground? Do you have TORS installed on the bike? Ohm everything and work your way back from them. You will not be able to Ohm the CDI it is solidstate.
