sheerider1026
    4
Everything posted by sheerider1026
  1. Cold temps/air will lean it out. Try bigger main jet and see if it helps
  2. Wow. Did u bleed the air off the top of the Head ? Re check impeller and gear. Maybe radiator is plugged? It sounds like a bad head gasket tho to be honest. Its a bad oring if it's a coolhead
  3. Really? U put red loctite on the taper? Or threads?
  4. Hmm. Sounds like flywheel key? But as stated. Check the obvious. Compression test first
  5. Why not just get some yfz450 calipers?
  6. Yea. I'd make sure your ignition isn't weak. Mr Paul
  7. Check the choke tube between the carbs. Make sure you don't have the slides in the wrong carbs ( they be backwards if so)
  8. Have you played with the air screws? 290 main sounds lean to be at sea level imo
  9. Dam. I just started using imageshack. Technical difficulties. I can txt pics tho. 5023311360
  10. Post man be madder Dan a mofo at Brian's house!!
