If it was me, I would put a new o-ring on it. Yamabond would hold in place yes, but, the way the cases are machined that(yamabond), even only if a couple thou thick, will change the tolerance on the cases to bearing(causing air leaks and other stupid stuff) not to mention if you put to much when you torque the cases you will have that shit in the bearing.. and running no pin stop or o-ring is a bad idea also. It will cause chatter and you will be looking for new cases. The cases(alum) heat up faster than the steel so in turn will try and spin the bearings in the case of nothing is retaining it.. JMO
