strokerace
    black fullbore plastic 10over swing arm -1 a-arms drag axle spindel mount wheels 688 cc motor on alcohol
strokerace's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. custom programmed mine ran great for about a month then startedgetting kick back when i tried starting it causing me to break every thing from a kick idle gear to the clutch basket drive gear even a clutch cover because the pieces got jamed broke everything a least twice put stock bax on it runs fine no problems
  2. strokerace
    dyna box
    anyone ever had any trouble with dyna box losing its program or advancing timing to far
  3. yes thats what i have hurd about the turbo bikes talked myself out of doing that really leaning toward the 4 mill over the 10 but i really dont knoweven thought about a 7 i going to start on this in the winter so im not rushed on time going to put new motor in drag frame i already have and put 18 in a rigid frame and i have to get thet done first
  4. i already have the 4 mill crank and plan on building it over winter dont really know if i want to build the 10 because how much faster will it be over the 4 and i already got my 18mill just kind of weighing out the two the 4 mill will rev to the moon and the 10 has more torque but just dont know kim at k&t said the 4 mill dm screamed like a raped ape
  5. talked to a few people say the 4 mil d.m. is tearing alot bigger bike a new ass
  6. yes that motor is in need of major repairs i would put in a small stroke say 12 or 14 and put some cub,cheetah cyl or something of that nature and carbs reed cages intake timing plate new pipes some shearers, longer swing arm ,axle,a-arms shocks and after that shee should be ready to rip
  7. p.m. me a price so i know whether to buy it or send mine off to get done thanks
  8. a pigs a pig nomatter where they go to bad they always fuck it up for the majority of the people if you pack it in pack it out
  9. THE ONLY REASON IS BECAUSE THEYRE SLOWER PLAIN AND SIMPLE
  10. not the ones in my sig but i have a fiberglass front piece and cut factory rears
  11. seperate the cases you dont even have to take the cylinders off the upper case halfs if motors not in the bike it shouldnt take more than 45 min to repair and put back together and if you havnt fired it the seals should still be good and reusable dont waste your motor over 45 miniutes work leave the top end bolted together and take case bolts out seperate case halfs clean case surface turn crank seal around put yamabond or other sealant on case half torque back down and done took mine apart a few weeks back and took like 2 hours and that was taking motor out of frame and replacing tranny and putting it back in the frame
  12. whats wrong with it and what does it come with also price
  13. what you looking to get out of it i might be interested for the right price
  14. im putting the 18mill i built this spring on it and building a 4 or 10 mill for the frame i have now this winter i hope to have the rigis with my 18 mill done in a few weeks but my other will be done in spring
  15. vic will be playing ball this year till just be 2 of them at the other end of bubbas dick "i love pitts thats my dog of choice if raised right they are just as good as any and better than most)my dogs aim to please and are smart as tacks
