Coupelx
    7
Everything posted by Coupelx
  1. if you are gonna buy something. get the correct wheels and be done. i already had the wheels so it was a no brainer to spend $10 on some hubs.
  2. atf here. do a search. this has been beaten to death several times over.
  3. you are talking like you turn the bolt but nothing happens. it just spins? get a pair of vice grips and pull on it while you turn it. worse case you have to cut the head off and punch it out/
  4. i along with many others run blaster hubs. i did it originally because 8inch blaster wheels are easier to find.
  5. if it were not for people trying "out in left field" setups, motorsports would not be where it is today. so many fucking haters. i just wanna see some turbo banshees.
  6. this one? http://bansheehq.com/forums/index.php?showtopic=139290 the rest of your posts. http://bansheehq.com/forums/index.php?app=core&module=search&do=user_posts&mid=38330&search_filter_app[forums]=1&view_by_title=1
  7. 95 is the start of the new style.
  8. exactly i like to find a nice thick oring to replace the factory one to stop the rattle and keep the grease in and then pack it full of grease. no reason to fix what isnt broke when all it needs is a little grease.
  9. there is no reason to buy another set of domes just to run race gas. you will not get a bunch of power out of it and "race" gas by itself does not produce any power on top of pump gas. High octane gas is for those who are limited by detonation on pump gas. save yourself some money.
  10. these things are a dune eating SOB. I dont even use a paddle.
  11. yea so i guess i owe you money then?
  12. i am thinking this guy is where the douchebag dirtbike rider stereotype came from. so in keeping with the theme here, i got a yz490 that says your shit is slow.
  13. sounds like you need new orings in the pipes where they hook to the jugs
  14. hmm, i guess i must have a uber special transmission that doesnt wear because its sitting on the bench looking pretty right now! there are ALOT of people using atf. it works fine. do a search on it even. i will agree that it breaks down faster. but at a couple bucks a bottle i will change it more since clutch life has doubled for me.
  15. running standard 10w30 will make the clutch slip. drain it, flush it out with Type F automatic transmission fluid and then refill with Type F. the cheap shit. no synthetic. change it every couple rides.
  16. did you find one that worked? ran across them awhile back looking for something else. the only other thing i have ever seen them on is some arctic cat quads.
  17. http://www.summitracing.com/search/?keyword=double%20banjo&dds=1
  18. So would it have been that much harder to type rapTOR than rapPY? seriously? kinda like saying tranny. i guess if you are into chicks with dicks...
