Coupelx
    7
Everything posted by Coupelx
  1. Port timings are only part of the story. Kinda like the preface to a novel. I did a set of stock cylinders over a couple years always trying new things and was very happy with them but i decided to step up to a pv cheetah which Wildcard built for me. Its fast its smooth and no anxiety or headache i figuring it out on my own.
  2. Little late you fucking moron.
  3. Just pic a number that makes your dick look bigger and impresses your friends.
  4. I dont have the typical hit of the powerband with powervalves so i can get away with less.
  5. Fuckin pipes are gonna sign off before the engine ever makes any real power.
  6. Yep. I went to a 4 over with my cheetah and dont like it. Its fun in hill shoots since it wont stand up but boring everwhere else because you have to make it wheelie. I like a bike that the frontend comes up with the throttle.
  7. They are vent lines. Route them as you see fit. My bike never sees water and i removed the vent on the clutch cover so i just let the one at the back of the cases hang down with the carb vent lines.
  8. I also use vaseline. Did the bike overheat prior to this? I have found it to be hard on the orings usually leading to this.
  9. That is not how the choke works on an atv. Get the fuck out of here and get some spell check. There really is no too low if it will sit there and not die. You can drink a beer in between each cylinder firing on mine. But i have also put the tuning time into it. Others like a faster idle. Yes that much elevation change makes a huge difference.
  10. Wrong forum nooblet. Forks remain in the same position.
  11. Its the blaster piston, 573, that is different. It was used alot before the invention of the 795.
  12. Mark top dead center on a pencil and then rotate it and mark bottom dead center. 54mm is stock 58 is a +4.
  13. Depends on where the transfers are at which is probably stock which means its probably not alot of fun to ride unless its wfo in the open. 192 would be considered a "dune" port by the general public.
  14. The weather magicians never have a clue. Its been decent here though until today.
  15. Why would you replace an almost bulletproof system?
  16. Nothing wrong with the stock one.
  17. Took 5 months to get my cheetah back from wildcard. Yea the wait sucks but good shit takes time.
  18. nice attempt at a back pedal. theres a whole range of setups befpre you ever get into "drag" porting.
