350shee
About 350shee
  • Birthday 12/15/1981
    Pac NW
350shee's Achievements
  1. yep drain your tranny fluid, coolant, you have to take off the R foot peg, your kickstarter, the breather tube comming out of the top of the clutch cover by the water pump spigot(SP) take out the nine cover bolts dont strip them they are a pain to get out!!! your coolant hose through the cases will be very snug so you may have to wiggle it a bit to get her off. try not to pull your kicker out with it, since your new it could be a pain for ya! then you have complete access to the right side of your engine.
  2. more than likley welded the push rod to the ball, or you lost the nut on the adjuster and everything went loose. if you lost the nut its floating around in your oil somewhere.better find it!!!
  3. free bump for me....always open to offers.
  4. Hey thanks for the free bump Josh! much appreciated. Sorry no pics. you can go to www.directdrivecnc.net if you like.
  5. me personally i would not buy any type of metal impeller, I have witnessed in several applications where the metal impellers make grooves in the clutch cover where the impeller rides on the clutch cover surface...IMO modquad or pro design needs to make a impeller that flows just like their billet ones, but make it out of a high quality plastic.
  6. NEW Direct Drive Banshee clutch cover and lockout cover is polished. with clear lexan. $325+shipping
