ONLY2STROKES
Everything posted by ONLY2STROKES
  1. is this 300'? do they run the quads heads up, bracket, or index?
  2. $35 plus shipping. one small ding, some scratches on lips, otherwise really nice. pics:
  3. they sell kits on ebay. all springs and new o rings for like 15 tyd.
  4. no, you can not. the piston will not be in the right position in the cylinder on each stroke. you will need the porting adjusted. also either a spacer or the head cut, possibly both depending on exactly how you are setting it up. you have a stock stroke now with 115mm rods. basicly same results as if adding a stroker crank with 110 rods to an all stock engine.
  5. the wheels and tires where new as of mid summer. i ran a handful of races with them. one tire has been plugged and leaks down to about 3psi slowly. i would fill it before every race and it would hold well throughout the day. bearings in the hubs turn freely, but have a little play. i ran these over 100mph on the dirt and never had a problem. they are very light and measure 17.5" tall. tire size is 4.00-10. will have better pics later. $150 plus shipping.
  6. yeah the dyna should only need the 12V pos volts from the battery. the other wires will only run off of the trigger wore for the coils. im not a sportbike electronics expert, so i would find out for sure. but looks like one would work on your R6.
  7. you will leave at the exact same rpm every time. it is alot different, takes some getting used to. some like it, some dont.
  8. i was just looking at the pdf wiring download. couldnt see why it would not work, but i could be wrong.
