Screaming Yellow Zonker
Contact Methods
  • Website URL
    http://motownmuscle.com
    Oxford, Michigan the gravel pit capital
Screaming Yellow Zonker's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. I have a 4mm stroker on stock port cylinders. I use the provided spacer plate and even with stock port cylinders it rips. If you don't want to use a spacer plate than you will have to have the cylinders ported for the 4mm.
  2. If you were looking to extract every bit of power out of that motor and didn't care about having to rebuild after a few runs than higher timing is ok. but if you you are looking for longevity than lower timing is better for you. As stated above with your combo you will be happy with staying at 4*. I would rather ride back to my truck than get towed....
  3. I kept having problems with my stock 26's. I got a 2 into 1 (or some say 1 into 2) with a 38mm air striker carb and the damn thing runs 100% better. before I was emptying the bowls of all the fuel and now I have no issues. I have also gone to the dunes a few times and personally I didn't notice any power loss in the top end. I'm sure a dyno might prove me wrong.... Some love them some hate them.
  4. Mine did that while I was warming it up. I started replacing everything. As soon as I put a new CDI box on it fired right up. (May not be your problem) If you have a friend with a Banshee swap out CDI boxes an see if yours fires right up...
  5. When you turned the screw out you changed the air fuel ratio to lean. That is going to be one reason why it does not want to start. Running too lean will lead to reduced weight in your pistions via holes. I would have started with reading the plugs and checking spark at the plugs. When is the last time the plugs were changed? How is the condition of the wires and coil? Are there any mods to the bike?
  6. I have made the trip from the northern end of Detroit a few times. I traveled to San Diego and with 2 drivers it took 42 hours non stop. Rest stop and gas station food can get old. I do plan on making another trip but that will be next year. Good luck with the trip and have fun...
  7. If this is dumb I apologize. But did you unplug all the TORS plugs? Not just off the carbs but off the throttle and the clutch? I got a wire diagram and cut mine off the CDI box also.
  8. Are you kidding me???? I don't know what type of drill bit you are using but I use carbide drill bits and it is harder that hell to drill into... I just tapped mine out to 7/16 and have not had a problem in this 6 years it has been done.
  9. Fixed... I run B8ES and/or BR8ES. If they are out of the B8ES I will get the resistor plug.
  10. Like most of my junk this might be a fluke but my bike runs pretty good with the Trinity 2 into 1 intake with the 38mm air striker.
  11. X2 Those fattys are good for a slightly modified (stock) bike. But not made for the big bore set up.
  12. There is no need to rebuild a perfectly good top end...... In my opinion it sounds like you might have a fuel issue. Have the carbs ever been apart for a cleaning after the jetting? How do your reeds look? (assuming you have stock they are probably cracked or warped) SYZ
  13. That thing is going to vibrate in a bad way. Which could cause the basket to come apart. If that happens it could damage the crankcase. It is not worth the risk. But if your friend has money flowing out of his ears than go for it.
  14. The TORS (Throttle Over Ride Switch) has a tendency to cut spark. Sometimes do to a faulty switch. The easiest way is to unplug the TORS system from the carbs, thumb throttle and brain box. If that fixes your problem you are on your way. If not it was a cheap way to start. Good luck SYZ
  15. Save your money for a good set. Those just don't seem to be reliable.
