If your vent(s) arent plugged & youre sure its trans & not carb drip. get a gasket & oring . If you want to plan ahead get seal & wp stuff jic & investigate
Motor wasn't even that hot or... that hot out
oem/ genuine: cdi, cylinders, carbs?
carb bowls on correct carb, crossover tube on, slides in correct, rats nest in pipes, pick up gap, good ground...,...
Tell us what it was...
So skeeter doesnt do it.
Thats what this site is for.
There's no sense in making a post, if you don't reveal the answers to your questions,for the next guy/Ky'ean.
What year ?
You sure the black doesnt have a red stripe
<2001
Black on harness goes to B/W on main switch
And R/B on harness to B/R on switch
B/Y should be TORS & not hooked to black ( but i assume thats all disconnected any ways?)
Float level ?
if its flooding down low ( not using the flooded fuel to lower the level) it'll be way under power down low, then when it clears out ( and uses enough fuel to not overflow anymore) the power will seem more cause it coming off of no power down low? Tip up on end too, to see if there's fuel in the pipes?
