375hp banshees
    203
Everything posted by 375hp banshees
  1. yep been running wet on my BS Olds for 15+ yrs don't cut any corners & read, read, read the more you under stand the better you will be :thumbsup:
  2. money sent for; R caliper, clutch lever & case saver
  3. they have them at advance auto parts down here!
  4. yes, & i guess you have to atleast, have the small one on ?
  5. i think you ( and i) got the RIGHT side correct but... ok the instructions suck but rt side-take the smaller spacer slide it between the axle bearing & larger dia. splines(it will cover up a small part of the splines)*w/ the flat side towards the rotor& the groved towards the wheel hub so the snap ring will go into it) *thats how i read that & i 'm sure its correct but you can see how bad the instructions are so do what you think! install rotor hub slide axle into housing install the sproket hub left side 1) install the 3 piece lock nut OUTER piece goes 1 st ( my 3 - piece nut was all together & i put it on w/ the hex out like the pic) 2) install theC-clip the inner piece of the 3-piece lock nut will rest over the C-clip 3) using medium locktite ALLEN HEAD bolt & torque to 8 'ftlbs 4 for the narrowest (which is wider than stock)install the small spacer on the axil EDIT: i typo'd the first post so reread it here is what is wrong & it makes A big difference!!!! 3) using medium locktite ALLEN HEAD bolt & torque to 8 'ftlbs think you ( and i) got the RIGHT side correct but...
  6. THATS BACKWARDS!!! i'll send ya some pics as i just id mine & Kiel sent me some pic's here ya go right side looks ok another thanks again Kiel & ghostrider (though you probably weren't aware :biggrin: )
  7. every shee is different, i'm at 360 at sea level ...340 should be close enough to do a plug chop what are you switching from filter & jet wise?
  8. every shee is different, i'm at 360 at sea level ...340 should be close enough to do a plug chop what are you switching from filter & jet wise?
  9. every shee is different, i'm at 360 at sea level ...340 should be close enough to do a plug chop what are you switching form filter & jet wise?
  10. mine ripped the stem out the first time i ran them... I'll never do that again ::
  11. i just scrolled threw all of them from 1 link (faster that way, anyway :thumbsup: )
  12. oh yeah, welcome to the HQ, let the addiction begin :woot:
  13. damn Dan, your one of those clutch yankers huh LOL... nice, videos!! 87 you didn't have to much trouble hooking up you kept lifting up, about the 60' mark
  14. clean them often, keep every thing tight (so dirt doesn't get in )& keep filter clean & DRY!!...you should clean them real good if its been sitting anyway, but yes your slide/sides are stuck, or you have an air leak get the carbs clean first & go from there& get a clymers manuel
  15. hey dallas, how's the polaris going?
  16. possibly, start it up at night in A dark area & look for A glow or sparks ...it can travel threw the water on the boots also, if there is enough.
  17. i' ll take the case saver do you have the longer bolts also? are the calipers raptor also?
  18. Dave, was your shee talking smack, looks like shee got her gator taped up... good to see we aren't the only ones that improvise(sp) w/ our #'s I thought it was A red-neck southern thing GITERDONE!! nice pic's somebody was busy
  19. yep, 1/8 mile i hear ya, i hear there are alot of grants out there, that the gov. will give you to open places to ride ...I guess like me nobody has the time to run it & keep it afloat yep, & the ones that do get greedy ""Come on to Georgia we'd be glad to have ya!"" I need to get my bike set up b4 traveling that far all the other local tracks run on week nights & its to hard to do well dirt & asphalt's done, anybody know of any mud tracks they want to close up, just let me know i'm sure I can giterdone ::
  20. yes it can be repaired, jankab just did one for me ( the one that bansheeracer9 screwed me on) he does good work!!
  21. every time I get 1/2 way setup for racing the track folds WTF lease up again... hope they renew it... the bad thing is we had to go there to find out...I worked all night replacing my bent axle & mounting my new tires, just to show up & find this out... they could have put it on the answer machiene !!!! sorry, had to vent nothing else to do, now
  22. you can invert your hubs for A couple inches also
  23. he didn't go today(suprise suprise) but maybe tomorrow,there is plenty of dry just have to puddle jump to get back to it, i think after you guys see it youl never want to go to the other wooped out places again!! i would like to hit up your place fast maybe in the near future. going to the drag strip, I'll get w/ gary see ya!!
