375hp banshees
    203
Everything posted by 375hp banshees
  1. I find that HARDA to believe w/ those mods? oops i thought you were saying you ran 7 sec in the 1/8 you ment 7's(700 ) my bad
  2. what are your mods to get into the7's
  3. yes ,its the first thing i did when i got it !!
  4. i was ok w/ stock piolot at sea level?
  5. yep, my jj&a came w/ a long dowl w/ a rubber boot for a handle
  6. ^^^yep, porting is like a cam & porting the heads on a four stroke at the same time..boring doesnt realy help unless you go really big but thats a waste imo
  7. that worked .... i was hoping on a fancy rotor :shrug:
  8. you could try threading a bolt into the race & try jacking it out...use something bigger than the od of the race ( i'll use a 3/4 drive socket for a visual) put the socket over the hole large opening down... put a washer on top of the socket (sq. drive end) put the bolt (that you already fitted to be able to thread into the race & get a good grab ) throught the top & thread it into the race...if you get a good grab it should start to pull the race out you might have to find the right length bolt or shim it as you go... just make sure what ever you use (in place of the socket) is deep enough to alow the race to come up into it & is a large enough id to alow it also good luck
  9. lol, he could use the true duct tape, that looks like chrome. lol
  10. yep, the tree starts the same for both lanes & you have to get as close to that time w/o going faster & still beat the other bike...we had set indexes... 5.0 ,6.0 it was a sandbaggers haven... there must be alot of bikes if they are going to be able to run averybodys trial times as a class?
  11. i was wondering what you got from troy, you should of said you were comming down ,we could of gottten a ride together, to go out on its maden voyage... that drag bike is sweet isn't it!
  12. your brake caloper is holding the rotor from coming off, which is attached to the hub... looks like you have the nut to the hub off, remove the caliper & it should just pull off
  13. don't they make large flowing fuel inlets? (float needle & seat)
  14. strapped a proto type on my old one to see & it got stolen. it worked, just ugly (on the outside of the rad. guard) ...you need small computer (hi flow) fans so you can put on the inside (4, 2 on each side of the steer stem & do dc convertion or battery or both ...SOMEDODY is suposed to post a how to & hasn't done it yet ... JOE !!
  15. forgot about the store, but yeah it need to be updated at the least cafepress store
  16. hey bseckel ,are you, or do you ride w/, the black shee w/ no plastics?
