375hp banshees
    203
Everything posted by 375hp banshees
  1. That's what I heard . I don't know why he doesn't just remake them since it's known everybody's trimming them Sent from my XT1585 using Tapatalk
  2. Don't go off topic now Sent from my XT1585 using Tapatalk
  3. Iirc, you usually have to do a little bit of triming. ( Might be for stock covers tho... Just don't freak out if it doesn't fit perfectly. FYI also, they sell different ones for a different sprocket size ranges. so before you trim, make sure you got the right one Sent from my XT1585 using Tapatalk
  4. What did you use like an RV AC DC converter or super low amp converter like a phone charger? Sent from my XT1585 using Tapatalk
  5. Elaborate. AC DC converter as in rectifier? Yes you will need a regulator as well , most use combined reg/rec unit Sent from my XT1585 using Tapatalk
  6. No, stock location is under the seat Sent from my XT1585 using Tapatalk
  7. You can look and see what he has for a voltage regulator if it's stock or if it's an aftermarket rectifier/ regulator... You don't have to have the battery like the JL... it's nice but, with the Floated ground and the rectifier, the stator/rectifier just runs your DC circuit separately, ie. your lights Sent from my XT1585 using Tapatalk
  8. Flywheels easy just get the proper puller &. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.jlengineering.org/banshee-stator-dc-convers.html&ved=2ahUKEwim-vKnov7kAhVMuVkKHT1jBJYQFjABegQIBhAC&usg=AOvVaw3E_JrHzB5K7vNrG8Ncpd1I&cshid=1570043108666 Sent from my XT1585 using Tapatalk
  9. Nope!!!! Sent from my XT1585 using Tapatalk
  10. Since AC is so finicky with them, might want to check them on a battery for diagnosing. iirc theyre polarity sensitive Sent from my XT1585 using Tapatalk
  11. You'll have to pull the flywheel & float your ground also to do DC Sent from my XT1585 using Tapatalk
  12. Don't see why not, Helicoil it if it's not to wallered out Sent from my XT1585 using Tapatalk
  13. Lectron Sent from my XT1585 using Tapatalk
  14. Yes, so pipes don't crack Yes, everydody talks highly of the DRW case savers? think it's Weston rainwater on FB? Sent from my XT1585 using Tapatalk
  15. Don't forget pipe hangers and case saver Sent from my XT1585 using Tapatalk
  16. Iirc usually 1-1/2 turns on air( if jetted correctly) if to far off of that rejet. Set idol to your preferred rpm usually checked with vac. Gauge/ Sync tool to make sure they are sync'd Some set idol with cable & some with screws. then check sync. again at higher Rpms ( or sight in the windows @ wot ; off) to verify sync. Sent from my XT1585 using Tapatalk
  17. Is there another adjuster @ the Y ? Sent from my XT1585 using Tapatalk
  18. Edited.... Different Sent from my XT1585 using Tapatalk
  19. He got different tires Claude...fyi Sent from my XT1585 using Tapatalk
  20. Cuz you left him hang'n Sent from my XT1585 using Tapatalk
  21. Fast told/sold me longer ones with my 35's I got from them Sent from my XT1585 using Tapatalk
  22. That's what I assumed , but I didn't want to guess, since he had to order something... didn't want him to order the cable also, and find out he needs the longer adjusters and have to wait again. Sent from my XT1585 using Tapatalk
  23. I wouldn't order anything from vitos... Call f.a.s t. & See if they will answer. I would try to find out for sure, before ordering anything Sent from my XT1585 using Tapatalk
  24. That might not be the case, just throwing it out there Sent from my XT1585 using Tapatalk
  25. The only people that would know that are people that have went from lectrons to keihin before ( and a knowledgeable carb seller) but he probably didn't know you were going from lectrons to keihins so... Sent from my XT1585 using Tapatalk If that's the case I, haven't done that myself
