375hp banshees
    203
Everything posted by 375hp banshees
  1. If no coolant loss flush it again ( hot) oils cheap. I assume you dont have access to a coolant pressure tester. Download tapatalk for pic's
  2. Stand alone , You cant hook that to your stator ( unless it's been dc converted) the stator is a.c. Try it stand alone for trailtech only & see if the results are what you are looking for Also alot of people are using power tool batteries fyi
  3. Oh they were cut way back at the stator? the yellow (yellow w/ red) depending on year, goes to reg. & T's up front to power up the switch. According to clymer DCV(but ive seen misprints) just try it on ac & dc ...with it running of course If nothings good, cut & ohm y or y/r & black , it should be between .26-.38 ohms...not running, cold Yes you need a regulator & seal up those butt connectors!
  4. Can you twist 1 up & in & the other down & in
  5. Idol screw count doesnt matter, use them to synch by gauge not turn count. set air mixture screws the same, to get desired mixture
  6. The most common way is float stator ground & get reg./rec. With or with out a battery. if you go led w/ ac , it's hit or miss ( more miss) if they will work or work for very long... as you can see by what you have now Or install a battery & charge it with a wall charger & isolate lights to just battery Sent from my SM-A505U using Tapatalk
  7. 11.5@ 2500 rpm, up to 16.3 @8,000 ( if above 16.3 reg. is bad). you can unplug it & check@ plug black as neg. Then yellow & green are hi/low b+ Sent from my SM-A505U using Tapatalk
  8. Put a meter on the socket & if it's good put ac bulbs back in it. most leds wont last with ac ( Unless it's DC converted) then check with meter & put leds in if v's are good Sent from my SM-A505U using Tapatalk
  9. But your working hard in a 8yr. Old thread so, maybe you oughta try working smart instead
  10. I believe the cdi can be hit or miss. South texas banshee sells adapters so i believe all cdi's will interchange if wired correctly. Sent from my SM-A505U using Tapatalk
  11. ^ Yeah all this info is no good, if you dont post results! Sent from my SM-A505U using Tapatalk
  12. @SKEETER you're a bad influence Sent from my SM-A505U using Tapatalk
  13. Why? thats what shop vac's are for...waiting on pics Sent from my SM-A505U using Tapatalk
  14. Oem elec's? Check your Flywheel key, if it won't try to start With starting fluid it's more than likely electrical No pv Sent from my SM-A505U using Tapatalk
  15. Yeah i figured...but you were loaded hard doe Sent from my SM-A505U using Tapatalk
  16. Get in there with a pick or utility blade & straighten them out now, while you have time you know somethings gonna come up/ happen & your gonna need to remove it in a pinch & cuss your self later Sent from my SM-A505U using Tapatalk
  17. Yeah, i was gonna let your ""sleeping when loaded hard"" comment slide, but since you brought it up Sent from my SM-A505U using Tapatalk
  18. ^ ^ Saw balls & had to join Sent from my SM-A505U using Tapatalk
  19. Pullers are cheap, work it back n forth with ALOT of anti seize, with a couple of pullers to keep threads good? After cleaning up as good as you can with a pick? Sent from my SM-A505U using Tapatalk
  20. ^^ ^^ ^^ Assuming you have slack in cable & your adjusted correctly now
  21. Well, you still have your left hand...thats a good sign, did she get scary with ya? Sent from my SM-A505U using Tapatalk
  22. I think 6'4 & 14" was his set up... you don't want pic's
