375hp banshees
    203
Everything posted by 375hp banshees
  1. Pull cover & inspect . If nothing loose, broken/ bent or out of adjustment, could have bent a fork & need to split
  2. I wouldn't do that, it won't idel Sent from my SM-A505U using Tapatalk
  3. Up Compression, better air filter / airbox mods, bump timing to 4゚, pipes, good tires, sprocket change to your liking... after that , you'll need to get port work done Sent from my SM-A505U using Tapatalk
  4. There is no set idol turns, did you sync carbs after? Intake gaskets tend to leak, might want to do a leakdown test too. Sent from my SM-A505U using Tapatalk
  5. case vent(s) , causing pressure, to blow seals out Sent from my SM-A505U using Tapatalk
  6. Make sure your vent isn't plugged
  7. What color? Sent from my SM-A505U using Tapatalk
  8. 97screamer Sent from my SM-A505U using Tapatalk
  9. Yes, it's the only thing i don't like about it...even when marked i second guess too
  10. Good deal... Out of curiosity what are you guys doing with your oem cylinders when you buy Chinese ones... there sure are ALOT of Chinese cylinders getting used. just wondering what everybody does with old ones?
  11. If it runs better with choke, it wants more fuel then You either have a restriction ( or fuel vent issue) or need larger main
  12. I would let it sit, kick it choked, a few times & if it doesn't start, pull plug& see if wet or dry Sent from my SM-A505U using Tapatalk
  13. You using choke? Does it start quicker after it's warm? Might need a larger pilot?
  14. Probably gonna be chasing your tail with non oem electronics & Chinese cylinders but... instead of pulling and changing the plugs just pull the wires Off and put them Back on & try & start with out changing plug. Edit: Try killing it by stalling it & then see if it'll restart Sent from my SM-A505U using Tapatalk
  15. And he's from orygun...so dats say'n sumpin Sent from my SM-A505U using Tapatalk
  16. Who gaf, buy q16 rub it on your top lip, run pump gas in your tank, & save your $
  17. Don't throw you old cylinders away ( if they are oem)... you'll need them next time Sent from my SM-A505U using Tapatalk
