375hp banshees
    203
Everything posted by 375hp banshees
  1. Guess you'll have to ask alba or there #1 fan...mr cLaRk Sent from my SM-A505U using Tapatalk
  2. Can you swap the joints top to bottom? Are they different lengths?
  3. What keeps the bottom tight It bottom out on joint flat spot? Can you put a 1/2 nut between arm & joint to space it out a little? I mean it can't un-thread but i wouldn't leave it loose
  4. How do you replace them? Sent from my SM-A505U using Tapatalk
  5. Can you suck your bottoms in more? Edit: Oops 0.30° *out Sent from my SM-A505U using Tapatalk
  6. Rule number one ;especially if your allready scratching your head; do 1 thing at a time. should've rebuild your carbs & ran and then did the reeds. I Assume You don't have the OG reeds. Did you verify your bowls? Inspected pipes better while doing leakdown? Tried other carbs? Single filter correct?
  7. i'll bet $ it's clutch setup! Sent from my SM-A505U using Tapatalk
  8. Breaking news... . ... . ... ... MINNEAPOLIS, MN—Prosecutor Steve Schleicher delivered powerful closing arguments today in the Derek Chauvin trial. In one especially touching moment, he made sure to individually address every member of the jury by name, phone number, and street address. "I call on you, [redacted] whose phone number is [redacted] and who lives at [redacted]," he said through tears. "Do the right thing and pronounce the defendant guilty. And you [redacted], who can be reached at [redacted] and usually comes home each night at 6pm, I implore you to do what's best for you and your adorable 2-year-old boy. It would be a shame if Antifa found out where he goes to school." Media reports indicated the jury appeared very moved by the closing arguments, as they were all shaking and crying by the end of them. In yet another touching gesture, Antifa has already shown up at all the addresses with bricks and Molotov cocktails to help protect them in case any fascists show up. Credit: Babylon bee
  9. If you think it's flooding. Shut the fuel off and see if it gets better when it gets low
  10. Long shot but try with choke on & see if it starts firing also bowls on correct carb?
  11. Explain set up for Going from? Stock port timing ? Pistons used? Domes used? Does it pass leakdown now? Case seems fine as in no rod sticking through & guessing...Damage found after?
  12. Keep all dem damn marbles inside fo sho Sent from my SM-A505U using Tapatalk
  13. @Sway what do you mean tested the water...test rode or literally ? Sent from my SM-A505U using Tapatalk
  14. @gusto it also broke head? & plugs backed out... then later the head busted, blowing o- ring out? Sent from my SM-A505U using Tapatalk
  15. Fuel & compression? What do the pistons look like? Sent from my SM-A505U using Tapatalk
  16. Did you do a leakdown Before after now?[emoji848][emoji848] Where did you read if plugs back out change pilots.[emoji2955][emoji2955] Did it blow oring/ start blowing our radiator, as soon as you fired it up w/ dif. pilots, or after you rode it a while with dif. Jets?[emoji3062][emoji3062] What size domes& main jets, timing?[emoji846] Sent from my SM-A505U using Tapatalk
  17. Not if your cylinders are stock or not ported for it. Is the piston # the same as one you pulled out? How did you end up with those new pistons? Sent from my SM-A505U using Tapatalk
  18. Сторона, которая не нагревается, не получает топлива. попробуйте потянуть воздушную заслонку с этой стороны и посмотрите, поможет ли это. если да, то с этой стороны что-то забито в карбюраторе
  19. Not tapatalk...say it aint so Sent from my SM-A505U using Tapatalk
  20. He's not from Missouri geeze Sent from my SM-A505U using Tapatalk
  21. Yes, no need to take all apart, just enough to r&r bushings Sent from my SM-A505U using Tapatalk
  22. Or try this? Dennis?? Sent from my SM-A505U using Tapatalk
