375hp banshees
    203
Everything posted by 375hp banshees
  1. Why did you change the domes, you get them from brian also?
  2. Grab your pipe springs & see it it's them, does it only do it as your letting off? Not at a constant rpm or on the way up? Sent from my SM-A505U using Tapatalk
  3. Complete motor? What'd Brian say? Sent from my SM-A505U using Tapatalk
  4. Looks like that wan stunnah fellers , buying airy body drinks for the week. (Tho it looks like the entertainment he was providing, will be canceled) https://www.usnews.com/news/best-states/indiana/articles/2020-12-17/parents-lose-lawsuit-over-destruction-of-sons-porn-stash
  5. The 6908 should replace the 6007. but jj&a specifically says 6908 are not to convert, just to replace existing 40 m.m. They both are 62m.m. o.d. unless they are worried about the 2m.m. width difference. I wouldnt think that would be an issue...but maybe
  6. I knew that, i'm not from ...Oregon
  7. Are all round house bearing carriers the same? ie can i put my 40mm shaft in my stock size axle carrier by just changing bearings & seals? ...All banshee stuff of course
  8. It doesn't appear to be Ray, but I'd be very carefull of anything that comes out of Macomb, Mi. There was somebody making those tho, seems like ayesully knows him?
  9. https://www.bansheehq.com/forums/index.php?/topic/188396-banshee-cylinder-information-thread/
  10. Yeah it's the one in the quad that goes bad, from sitting
  11. Yep, i tried that no toil brand foam style on the polaris...same thing Everybody's gone to cheap products these days. They would always break down, but a lot quicker now it seems.
  12. I'd rather keep polishing it than spray bomb it
  13. You should find out what it was, for you next time & post here for others
  14. Cant help ya there, running stock, somebody will chime in, and as caleb said, water wetter or engine ice instead of coolant... helps
  15. https://mullengineering.com/rt/ Sent from my SM-A505U using Tapatalk
  16. Lol ...chill go have a cold one... oh wait🍻
  17. Oh ok it's only 90° there & 92° here...but what ever... good luck
  18. Stock radiator should be fine, unless you're idling around with no air flow, or you have other issues
  19. Hez gotta leak damnit Tapatalk ftmfw Sent from my SM-A505U using Tapatalk
  20. Usually the crack isnt leaking ( usually cracks around the bolts). there is a round piece on the back that has an oring on the o.d. that seals it to the case. You can lean it over to keep oil away & remove white piece & match oring up locally or buy a new cover with oring . they sell billet ones ( you cant see it but they hold up better) did you make sure your vent lines were open? Sent from my SM-A505U using Tapatalk
  21. Theres one by water pump & one at rear motor mount. Not saying they're leaking ,but if not venting properly it will build up pressure & cause leaks. if your saver bolts to the 3 bolt ( white kinda triangular) plug by sprocket , it is sealed by an o-ring or could be sprocket seal, or vent/hose by waterpump
  22. Oring behind it leaking? Vents, venting properly? Sent from my SM-A505U using Tapatalk
