375hp banshees
    203
Everything posted by 375hp banshees
  1. Hard to see... how is the corner shaped Sent from my SM-A505U using Tapatalk
  2. Looks like you have air box on? try pm'ng ayesully he's pretty good at jetting ...hasn't been on in a while tho...maybe a he' ll get a pm tho? Sent from my SM-A505U using Tapatalk
  3. Are the corners of the reed cages at a single 90° "L" ...or are they "\_/" Sent from my SM-A505U using Tapatalk
  4. Filters aren't over oiled? & see above edit reeds Sent from my SM-A505U using Tapatalk
  5. Youre sure theyre not knock offs? or reeds Corners 90° or cutoff?? Still have OG's Cylinders?... ported? Sent from my SM-A505U using Tapatalk
  6. Technically it runs leaner but... fatter oil wise. Shake the shit out of the quad, to stir up oil , & pull hose to get rid of oily mixture @ bottom of tank. tip it on its grab bar, to see if fuel runs out of pipes. If it'll run, after warming it up, rev the shit out of it, while pulling choke on & off. Otherwise re- clean carbs?
  7. How long between good 3hr. Run & won't run? Are you sure theyre genuine Keihin carb's ? there's ALOT of fakes out there. my keihins got clogged with oil, alot easier than stock carb's. only thing i can think of is fuel vent, but it sounds like youre to rich, as it is.
  8. I think STB sells adapters, if you think it's worth trying before spending$300+ & might be handy in the future too
  9. No aftermarket ! ... partzilla Its a 3GG-85540-10-00 I think Oops thats '97 3GG-85540-00-00 Sent from my SM-A505U using Tapatalk
  10. Yes common , swap with a known one if possible, is the only way to test. Buy oem only! Used ones are readily available Sent from my SM-A505U using Tapatalk
  11. Is it ported? What cylinders What brand / size carb's ( same ones as before rebuild?) Did your pipes sit where there could be a nest in one? Since it runs, choke tube must be on & slides in correct carb. What about correct bowl on correct side?
  12. Thats not what i heard
  13. ^^ Will it collapse here, to fit here, or is it bottomed out internally? If not , ratchet strap it & install, then test range of motion Sent from my SM-A505U using Tapatalk
  14. They don't call them knock off's for nothing
  15. Was fun times ...15 years ago Been closed for 15 years & so have all the others... since
  16. Next time dont get glass ...depends on your riding style really ...but Jeff would probably say otherwise And... do you want to take a chance & find out, on a new build.
