203
Everything posted by 375hp banshees
thanks :baseball_bat: MinEsFasteR79 i've been trying to do that & nobody would reply it worked thanks again :thumb: you might want to make yours smaller I've seen complaints B-4
whats the rule of thumb for mounting paddles alot of my trails are packed, does it ride smother to stagger L. to RT. or align them. Any opinions on gecho's ?? Like I said sand is tightly packed just need more traction than my fast trekkers? & not to agressive
what about gecho's ?. no dunes but nothing but sand in fla .tired of spinning
just ordered geco's are they any good?? 21x10x9 I think putting them on my stock/spare rims. ride in fl. every thing is sandy but not like dunes. what we call dirt down here but it's basicly sand. I had 2 get something getting out run by everything due to wheel spin even take off in 3rd some times (stock sprockets)
Ocala Big Scrub Ride Out Idea
375hp banshees replied to chase@miamiatv.com's topic in Riding and Events Forum
i'm there, set it up crooms suck nothing but woooooooooooooooops :baseball_bat: now -
How do you clean your carburetors?
375hp banshees replied to night's topic in Banshee Repairs and Mods
cant figure out how to post pix yet? but in your 3rd pix "Clean the bowl out real good, including the choke tube." it's in the middle hole (between the drain &the over flow ? I didnt think much of it until I cleaned the right one & there wasn't one in that hole & there didn't seem to be threads either (sp) ?? just curious? it runs fine ?? also the #'s were 25 jet,350jet ,1.4jet??? those #'s seem low (or odd) compaired to some posts i've seen but plugs look good my mods are in my sig thanKs sea level -
big red what is the small 1.4 jet in the bowl port for (only in the left carb on my '04??) -
All you guys have temp gauges and have seen that much of A differance??? I ran it in my '87 due to alot of slow trail ridding (w/ my daughter) & didn't see much of A differance. Getting ready to put it in my '04 though it has to help some but I definatly didn't see that much & I have A gauge (on both), but my temp prob is due to low air flow maybe yours are due to mods ect.??
1975 banshee : rocket pipes with billet 2 into 1 silencer custom made with a hmf sport series exhaust, custom mud buster 4 mill cam ,billet cam spacer , 22inch super swampers , cases matched , crank split, stroked , rubbed and rebuilt with cast iron, powerband adjusted and a tripple mud port - hay mudslinger whats up w/ the'75 shee?
Since I've been here last I. . . earned Eagle scout, turned 18, graduted HS, and got a 91 geo metro (dont laugh its a college comuiter, i still have the F-150) CONGRATS!!!! waiting (PROCRASTINATING) until you are almost 18 sure makes it tough. My son did the same thing. It sure helps when you get most of it done before girls[/u][/i], cars, job ect. come into the picture!
cool that looks like where we go in holopaw (osciola co.) sp? my buddy I only banshee's though, the rest are 4x4 but there fun to watch what tires do you guys use in the sand (fla sand different than up north)
Is every body on your side? Do you ride over here at all?
verry low rpm rev limmiter takes over so you dont ride w/ P- brake on. if you disconnect it: there is a sensor on the lever that the two wires have to be connected together, or if you left linkage on & just removed the cable you can wire up the lever so that it pushes the senser in. It will start & idol but wont rev. above an idol (verry low rpm rev limmiter takes over so you dont ride w/ P- brake on)
anybody else from around here (besides chase & robert)
:baseball_mitt: thanx. 2" per side or total & what is the benefit for "-" , "+", forward besides length caster ?
"I removed the wires from the pirtch, cut and connected them. still wont run right. it sounds like that is the problem though. thats all i did since it was running. which was only a couple months ago. also when it isn't running i had it in gear and pulled the clutch and tried to push the bike and it wont move. but when i had it running i pulled in the clutch and popped it in gear and it just sat there. sounds like the brake system. this all happend once i removed my parking brake" my P-brake lever was wired together (where the cable used to hold it against the sw.when it was in the off position) when I bought it, it had the e- brake cable removed , but that sounds correct to hook then together?? Check your wires maybe 1 is cut therefore not completing curcuit (sp) that sounds like your prob. it cuts your ignition out (like A rev limmiter) just above an idol if your p-brake is on (or it thinks it is on) tors is another prob. for later it kills ignition completely when your carb's stick wot & it senses your throttle lever is at idol
I did the same thing. Put your mods in your sig. it will help alot in the future w/ diagnosing (sp)
what does the +2+1 ( A-arms) mean?
Stolen Banshee Ann Arbor Michigan
375hp banshees replied to dbkid13's topic in General Banshee Discussion
in fla. my ins. is $15 A month W/ $50 deductable . Had my '87 stolen 3 yrs ago , finaly replaced it ,had ins. the day I took it home . just got A $800 check in the mail for bent axil & misc. Definatly well worth it! hope you have better luck than me still missing I still have my drain plug , hope they never checked oil & it locked up wot in 6th gear (that thought is the only good thing) wish I Knew? good luck!! -
banshee's run hot when trail ridding SLOW or SOFT sand (putting w/ 4 pokers & kids) Iput A fan on my '87 shee & will be putting one on my '04 when ridding w/ my daughter it heats up quickly w/ no or little air flow. most people dont use temp gauges I guess?? I don' t see many post about it so here is my .02. still take A shee ,w/ fan If needed, over 4 poke though
wesley chapel, florida 20 min. N. of tampa. not many floridians on here (except miami area) & don't see many banshee's out ridding ,everybody's gone 4 stroke???
Dang didnt know TORS was that so picky!
375hp banshees replied to Walleye's topic in Banshee Repairs and Mods
" If you want to bypass it just unplug the little black box under the tank on the left side" my buddy has an '06(stock) & it just died no spark tried un plugging black box & still no spark if you blip the throttle it 1/2 fires & dies. pull started it blipping the throttle & it started & ran fine the rest of the day is there any thing else that needs to be un plogged?? (pulled throttle cover & micro sw. was clicking ??; no meeter w/ us ??) -
hey mudpuppy fix your shee yet??
sheeeeee's back ,well sorta previous owner removed p-brake cable & wired up the mechanism (because of +2 extention??) & apparently that switch cuts ignition out @ 4000. 4,000 to 17,000 at Apush of a button. A bent rim wasn't the only thing bent ,three cracked ribs/bent axil I'd say it was pretty even .thanks for all the help. read posts for years glad to join!! hope this will help you mudpuppy? posting my mods would have probably helped how do I put them at the bottom of my posts?
