jbooker82
  1. I run the Piaa H6M bulbs in my factory head lights. They are much brighter white light. I would recomend them.
  2. Cub style ports (tripple exhaust ports) with a Dune Port timings.
  3. Wich wires is it hooked up to and is it a normally open or closed switch?
  4. I just do a mexican bore job. Run it in the sand dunes with no air filters. Works great.
  5. Thanks man appreciate it. Just another year older.
  6. Is that duplicolor's Graphite Wheel Paint / coat? That is some good stuff. I painted a dumb and dumber mini bike and my raptor 660 engine with that stuff. It is a tough paint too.
  7. they also get scammers to take pics of them holing stupid signs.
  8. Tell the scammer that he needs to send you 20 bucks cash in the mail. Give him a sob story about not having any money for internet and transportation to the local library to use the net. That way you can get a pay pal account seup and get the ball rolling. Then when he sends you a 20 send him a stupid pic in the mail of some drunk clowns or something. Scam the Scammer. 20 might not sound like much but in nigeria it is and he will be pissed. Heck even 10 bucks is a lot. The Kill Stories are great. 419 Eater http://www.419eater.com/index.php
  9. They are a good general pipe. They give good power through out the rpm range. CPI's, Shearer's, Rocktes, Sniper's, are drag pipes. Their power deilvery is geared twards top end. Some come on sooner and pull a little better down low. Others build a few hp up top. CPI's are a popular choice for high speed general riding due to the fact that they come on sooner and pull pretty good from the midrange to top end. Shearers suposedly have a harder hit higher up in the rpms, and make a few hp over the CPI's. With a 2 stroke your always exchanging something to gain something. You want bottom end it is going to cost you top end and vise versa. CPI's have been compaired to Toomey T5's on sterroids. I run CPI's because they are hard pulling top end pipe that still maintains a desent midrange.
  10. Yea cobra maks an oval clamp on sparkie but the look and fit like crap. I would sell your silencers and get a set of FMF Turbine Core II silencers. They are a spark arrested silencer and have a much better flowing spark arrestor than the screen cobra sparkie style.
  11. Jeff at FAST is 130 miles straight south of you in Holton, KS.
  12. Thanks man. It is just my 97 look a like 06 LE. Only with a black chrome and glitter clear pc'ed frame.
  13. They could have. Mine were real mikuni boots. The part number was right on the lip of the boot. You can kind of see them in this pic.
  14. I thought you removed the bolt so the passage was open
  15. i run one of their short ones on the LH stinger.
  16. I have herd if they the battery goes dead then you have to reinstall any apps, or files that did not come installed from the factory. It is like it looses its memory. That is with the Ipad. I dont know about the Ipad 2. I have been looking at the Motorola Xoom powered by android honeycomb
  17. I wouldnt worry about the silicone. The transmission should chew it up pretty easly. It will come out when you chage the oil.
  18. I run 10 deg angled k&n's with a boss billit internal crossover intake.
  19. x3 Here is a chart. http://www.nossmachine.com/banshee_heads.htm
  20. Boss intake is a good intake. They dont mfg their own intake boots. Mine came with Genuine Mikuni carb boots. Look on the lip it should say Mikuni and have a part number somthing like this. VM 34-200. The problem isnt with the boots. When you get fuel on the boots it softens them up a little. Then when you overtighten the clamp the clamp cuts the boots. Dont overtighten it and you wont have a problem. Buy a couple to keep on hand. These are the ones on my boss intake for 33-35mm carbs. $16 bucks each http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=1867&catId=311&leafCatId=31102 Most aftermarket billit intakes use mikuni boots.
  21. Yep. Klotz Supertechniplate, Klotz Benol, Klotz Original Techniplate, Maxima 927, and I am not to sure on this one. Redline. Ethanol is way less harsh / corosive than Methanol as well.
  22. Is it backfiring out the exhaust or back through the carb. If it is back firing through the carb you better check the reeds. It doesnt take very many to toast a set of reeds.
  23. Piaa H6M is what I run in both my raptor and banshee. They are about 25-30 bucks a bulb though.
