badxr6
badxr6's Achievements
  1. i have a little problem with the bike running a bit rich just off idle and some times fowls the the plugs this is what i have 35mm pj carbs bigbore sleeves 69.5mm pistons portted daul stage reeds portted reed cage plus4 timming pc pipes 19ccdomes prodesign head pilot jet is on the smallest 35 top slot on needles will idle air screw out heaps.will it help if i machine the throttle valve cut away some more cheers
  2. yes its not to bad i had to modify the slides were the neddles go through to lean it off at idle and low speed its not too bad now all ready has fat needles in it thats why i am going bigger bore etc to get the potential out of the carbys but just wanted to see if there was a better exhaust out there than what i have p.s i have twin 35mm not single
  3. the mods i have are in my sig plus the 69mm pistons which are coming
  4. would the t5 be better than the pc pipes for more horse power bearing in mind i am putting in the 69mm pistons
  5. just want to know if there is anything that could be better than what i have
  6. most of the riding i do is top end riding more than bottom end riding and i thinking of puting in big bore sleeves and pistons as well
  7. mid to top end i have pro-circuit but was woundering if t5s were better
  8. what are the t6s like are they better
  9. could any one suggest which is the best exhaust on the market for trail riding cheeers sorry missed out the p in pipes
