SAVAGE420
    18
Everything posted by SAVAGE420
  1. Good buyer. I sent him a swingarm and carrier the same day as he sent me a money order. He got his stuff and i got the money order. No nonsense here with tdod101
  2. http://bansheehq.com/forums/index.php?showtopic=167211&p=1483648 Simple as.... Good luck man.
  3. A bit low, ive run motors alot lower then that, all has been well. Post the new results. Kick with it pinned until the needle stops moving, then a few more...
  4. What you want to do is LOCK them together so they will not come apart on their own. 1. Torque the first nut to 40ft-lbs. 2. Torque the second nut onto the first nut to 140ft-lbs. 3. Make a straight line with a marker across both nuts. 4. Back the first nut off into the second nut to 170ft-lbs. 5. Measure the distance between the two marks, if not about 1/8", repeat the process. This will LOCK the nuts together, don't just tighten them down and hope for the best. The bearings will bind and eventually fuck up. No loctite is needed whatsoever.
  5. http://bansheehq.com/forums/index.php?showtopic=99361 Read that! ^^^ Elevation? Temps? ect... What's in there now for jets and adjustments? What's it doing now that is wrong and right?
  6. http://www.motovideo.com/browseproducts/Sandsation-Vol.-1.html
  7. I use this set. Worked well for 3 seasons now for the price. I don't use the upper roller though. Most don't. http://www.rockymountainatvmc.com/p/43/53/222/960/-/15907/Modquad-Chain-Slider-Guide-Set
  8. Just grab some insulation for now and wrap some in....pink panther style.
  9. Gettin it! Actually looked like a funday sunday. Would be paranoid to get jacked though....
  10. .....as said above, but go in sequence, hand tight,then 10 then 15 then 22....is what i do. The sequence is on the stock head 1 thru 10
  11. I would up it just a cunt hair higher.
  12. SAVAGE420
    Rear axle
    Why is yours fuct? Post a pic. The carrier is held on by 2 bolts/nuts, one upper and one lower. No castle nuts there, just 2 nuts and bolts. Simply undo the nuts and slide out bolts. Or can you not get the axle out? It comes out towards the brake hub. I'll pm you a vid if you can't figure it out..... So you need a swingarm, carrier, axle, all the hardware? I have the swingarm and carrier if thats all you need. Think i have the hardware as well.
  13. SAVAGE420
    Rear axle
    What ALL exactly do you need?
  14. Mine has lasted 5 years, still good. Haven't hit a tree or a retard yet thou.... It's in my Sig, wanna buy it?
