peterlocal22
1 Follower
About peterlocal22
  • Birthday 04/03/1976
Contact Methods
  • Website URL
    http://www.megamoneypicks.com www.commonwealthscaffold.com
  • ICQ
    Boston, Maasachusetts
  • Interests
    atvs, heavy equiptment, Erin D. and her wacko remarks!
    2004 Yamaha Banshee white and red Toomy T5's, Billet Iron Cross front pipe hangers, Billet rear pipe hangers, Delta 3V Force Reeds, Trinity 2 into 1 carb pilot jet 52 main 185 3 clip on the needle, Adj. timing plate, Uni Filter w/ Pro Flow Plate, PRM belly skid plate, hyper beed locks w maxis razor on the rear, Hyper Beedlocks w/ Kenda Klaws up front, Ac Racing Pro Pegs w/heel guards, ROX P2 S/P 2 inch risers, BLACK-PowerMadd Star Series Handguards w/Rox Billet Mounts ATV Handgaurd Kit, Fast Flexx bars 14 degree low bend 31 inch, Moose Thumb Throttle, ASV F3 Red Shorty Pro Model Clutch and Brake Levers, Scott grips, Billet hide a key, parking brake removed and skull block off, tors removed, ASR fully adj. +3+1 a arms with ASR tie rods, Front and rear steel braided brake lines, axis dual rate front shocks w ressies, Extreme Fabrications, chromed -2 Chrome Avenger swingarm w/ 3/4" Baja Racing skid plate tabs, .250 inch PRM Skid Plate, extended +2 +4 G Force axle, LSR Billet Alum. Brake Hub, Galfer Wave Brake Rotor, LSR Sprocket Hub, polished clutch cover with Iron Cross, Polished Billet water pump cover, Modquad Billet impeller, polished billet modquad stator cover w/flame design, chromed shifter, chromed brake petal, ESR Temp guaue, T.M design Case saver
peterlocal22's Achievements
HQ  Captain
HQ Captain (3/5)
6
  1. Its a joke, shut it down and you will be a lot happier
  2. Hi, yes I did and AMerican Star Manuf came up. Guess they changed their name?
  3. I bought a set of +3+1 a arms from them in early 2000. The upper and lower heims are worn out and need replacement. I cant seem to find these guys to order replacement parts. Are they still around? Anyone know where I can find new upper and lower heims or ball joints that will fit this a arm or am I out of luck? Thanks in advance, Peter
  4. I run a -2 swing arm and love it over stock but a bigger tire size will rub against it when suspensionis compressed. However if I was to do it again I would go with a -1. Nerf bars, skid plates, hyper beedlock wheels are all a must. Ive ran diff pipes and the Toomey T5s are still my fav for woods. Good luck with your build
  5. is anyone really buying used banshees for $6k or are people jusy trying to sell them for stupid money?
  6. sounds like an air leak when it reved to the moon, dieseling?
  7. I personally would not do the trade. Keep the banshee you will want it back at some point in your life
  8. I thinnk Prices are crazy right now because covid. Its shut down or delayed everything including new bike productions.
  9. Ive done both, carried a small fuel tank on the rear but this requires a bigger grab bar. Also carried just a small container of 2 stroke oil which was a lot easier and my preferance now.
