00tbanshee
1 Follower
About 00tbanshee
  • Birthday 04/12/1981
Contact Methods
  • Website URL
    http://
  • ICQ
    Williamsport,MD
  • Interests
    drag racing the banshee,hunting
    421 cub by HJR,way the economy is had to sell.once things turn back around going to work my way back into racing again
00tbanshee's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. i would run the 34 pjs.i ran a set converted to alky on my 4mil drag port that i had at one time and it was a beast!and all i did was drg racing.i agree that some times people tend to run to large of carbs
  2. yes just use one row around the clutch the other you won't need
  3. cut the hole to be on the safe side.if know anybody with a plasma cutter,it works great.just shoot a bead of silicone around the rubber seal when you bolt the plastic cover back on.make sure you locktite the 6 bolts that go in the springs.if not they will back out.also just use one row of balls.i've ran one of these and they work just fine.for the money i think they are worth it
  4. kevin from hjr is doing one or 2 right now!
  5. 60 over isn't nothing.i did a set of stockers set up for a 4mil drag port couple yrs back.pretty sure they are still on that bore
  6. damn, thats the most desperate sale post i have ever seen.lol.good to see you sold it though!
  7. ran a 1-5 n down in my 4mil cub motor that worked fine.,it was cut by wcr.have also road a few banshee's that have the same style tranny in from kevin at herrjugsracing and they seem to shift alil smoother.i always tore it apart after every season to check the forks and always had to replace atleast one.
  8. good luck.seen one that person had alil trouble getting $1250 for.yeah i know,i kick myself in the but for not snatching it up
  9. 34 pj's will work perfect.i ran one of kev's 4mil stock cylinder drag ports and they are what i used
  10. i can be sure if you send it to any of the site sponsors, they will be sure that you will have everything done right.you just have to let them know your riding style.length of your swingarm will also depend on your riding style.+4 is a all around good length
  11. call kev,he will tell you what you need to have
  12. ceg needle,170 main,50 pilot with the a/f screw 1/2 turn out.that main will be alittle rich but if you are going to hit olds hill any it will be safe
  13. go with the cub.you'd be much more happier
  14. man buddy,you just can't make your mind up what you want to build
