Ok,
Here is what I found out.
Found an online service manual, But not for my "04"
Anyway, The source and pickup coil test within spec.
The primary and secondary coil show no reading within the spec#'s at all. The right plug wire cap showed 23k ohm and the left showed no reading. screwed the caps back on the wires as I took them off and test rode. Still dropping the left from 1/4 to 1/2 throttle but came back in from 1/2 to full throttle.
Switched the left cap to the right side and the right cylinder was dropping from 1/4 to 1/2 throttle.
Right came back from 1/2 to full.
So, Should I buy just the caps for 21$ apiece and stay stock and try first before a new stock coil, Or go with whichever best aftermarket coil you all suggest!
