spurdy
    25
Everything posted by spurdy
  1. I redo all of my harnesses and cut out all the bs. Move the CDI close to the coil and the stator. Get rid of the extension cable. Cleans up nicely, gets rid of all the spots that can cause issues, and makes future troubleshooting easier. Sent from my iPhone using Tapatalk
  2. Not possible that they are burnt out if they will light with an external battery. Could be a bad connection in the harness or a failing voltage regulator. Sent from my iPhone using Tapatalk
  3. That's one thing that never happens, running out of beer. Lol! Sent from my iPhone using Tapatalk
  4. Well, I'd say some Miller Light but your OK beer is weak. Lol! You can have em. I don't need em. Sent from my iPhone using Tapatalk
  5. I've got a set of Yamaha rear hubs. Sent from my iPhone using Tapatalk
  6. How does the bead breaker work? I had a small one that mounted to the floor. I gave it away the same day it arrived. Sent from my iPhone using Tapatalk
  7. Legendary in more ways than one. Sent from my iPhone using Tapatalk
  8. That is one looong sentence! [emoji23] Sent from my iPhone using Tapatalk
  9. 1.5" seems excessive to me. Sent from my iPhone using Tapatalk
  10. I never said anything about changing chains Willy Nilly. However, if I had your money, I'm sure I could afford to burn mine. Lol! But seriously, I would just keep an eye on sprocket wear and gauge from that. Sent from my iPhone using Tapatalk
  11. How are you measuring? Length? Side play? As with all the equipment I've ever maintained chain stretch is irrelevant up to the point that it has stretched far enough to alter the pitch to a point that it begins to wear the sprockets. Just my 2 cents worth. Is business slow over there. Measuring chain wear....lol! Sent from my iPhone using Tapatalk
  12. [emoji16] Sent from my iPhone using Tapatalk
  13. I have a sick one I'll sell you. 2k. Sent from my iPhone using Tapatalk
  14. Won't hurt anything. Just gonna leak oil residue. Silicon will need time to set up and may blow out anyway. I usually use high temp rtv at my exhaust flange. Sent from my iPhone using Tapatalk
  15. What? The Yaris is a bad mofo! Lol! Sent from my iPhone using Tapatalk
  16. How did I get brought into this? Lol! Sent from my iPhone using Tapatalk
  17. I think Ryan's advice may be misinterpreted. The slides typically have no choice but to move at the same time since the are controlled by a single cable. What is important is that the position of the slide in the carb is identical. The slide raises and creates an opening for air to be drawn through. This open needs to be identical. The lever the opening, the more air flow allowed. The sync tool measures this air flow and allows you to get them set the same. You can also do this by eye but it isn't as accurate. Make sure as you begin to open the carbs, both slides come off the bottom position at the same time. Too much slack on one side can allow that carb to rest in the bottom position while the other slide begins to raise. Then make sure their heights are equal as they move up. Equal in one position means they will be equal in all positions, aside from the resting position. Sent from my iPhone using Tapatalk
  18. Hostility.....I think is how you put it. Sent from my iPhone using Tapatalk
  19. You'll not be able to ride doubles at LS on a quad that wasn't designed for doubles. Just so you know. Sent from my iPhone using Tapatalk
  20. Dennis drinks coors light. Lol! But probably would prefer some good riding as a thank you [emoji4] Sent from my iPhone using Tapatalk
