25
Everything posted by spurdy
Yeah, I've only dealt with Mike also. ASV levers, shocks, etc. only dealt with Mike and never have had any issues. Sent from my iPhone using Tapatalk
4 mil stock cylinder complete with gas 35 pwks, shearer oof sf sb pipes, lockup and direct drive cover, straight cut gears, 1-5 ND, 105 hp 58tq. Pm me if interested. Sent from my iPhone using Tapatalk
Dust covers shouldn't make a difference in your vertical movement. They are dust covers, not bushings. They protect the bushings from getting dirty. Your bushings, sleeve, and bolt should be what eliminates any play. Sent from my iPhone using Tapatalk
Clutch Cover- to vent or not to vent
spurdy replied to gunnin4elvis's topic in Banshee Repairs and Mods
Block it. Reason- not needed. Sent from my iPhone using Tapatalk -
banshee Banshee w/ 7mm Stroker
spurdy replied to 04BANSHEE7mmSTROKER's topic in General Banshee Discussion
I'm going with zero rpm for safe. Seems most applicable to me. Sent from my iPhone using Tapatalk- 10 replies
- banshee350
- rpm
(and 4 more)
Tagged with:
Safe zone? Sent from my iPhone using Tapatalk- 10 replies
- banshee350
- rpm
(and 4 more)
Tagged with:
Any shops that can remove this Flywheel?
spurdy replied to Banshee2105's topic in General Banshee Discussion
If someone has already had a 3 jaw puller on it there is a good chance that the woodruf key has rocked in the keyway. Once that happens your best bet is to tighten the nut down and try to reseat the flywheel. Then pull again. Last time I had that happen I couldn't get it to reseat. The key dug into the keyway on the flywheel and there was no way it was going to be pulled off. I bent a set of 2" thick cross beams in a hyd press trying to press the flywheel off. Have to be careful reseating it also. I snapped off the threaded end of a crank once also and the had to bore into the crank and add a threaded rod to repair it on a brand new crank. Once I cut the flywheel off there was a nice little gouge mark perpendicular to the keyway where the key had gotten wedged. So welding the flywheel puller to it may not work if this is the case. Sent from my iPhone using Tapatalk- 30 replies
4.5" grinder and a die grinder with a cut off wheel after I ground the river heads off with a grinding wheel. You just have to be careful not to cut into the taper of the crank. It's dirty and time consuming but it will save your crank and stator. Sent from my iPhone using Tapatalk- 30 replies
I've had to cut a couple off before. You can do it without damaging the crank or the stator if you take your time. If the woodruf key has rocked in the keyway, you will never pull it off or press it off. I had one stuck once and had it in a 10 ton press and it wouldn't budge. Sent from my iPhone using Tapatalk- 30 replies
This is completely wrong. He doubled the amount of oil he was told to use. He used 32 oz instead of 16 oz to the same amount of fuel. His Motor will be fine but your math needs some serious help. Lol! Sent from my iPhone using Tapatalk
^^^this. I wouldn't use loktight on the taper. That's just me. Well, me and this guy. Sent from my iPhone using Tapatalk
Be Very careful where you send your Motor!!!!!
spurdy replied to 887ru's topic in General Banshee Discussion
Bacon overrated? Wtf? Fried cheese and real bacon FTW. Sent from my iPhone using Tapatalk -
Mine came with em. I didn't use them. Sent from my iPhone using Tapatalk
I've bought all mine from atv galaxy too. Each set comes with a pump. Sent from my iPhone using Tapatalk
All you have to do is show up and race the peeps you've been talking shit. We post every race we will be at and encourage competition. But you've made it abundantly clear every time that you've no intent on doing so. Sent from my iPhone using Tapatalk -
Too bad you didn't have balls enough to actually attend the race. Sent from my iPhone using Tapatalk -
Some people will never learn no matter how much schooling you give em. Always running your cock sucker with nothin to back it up. Good to see I didn't miss the mark though. Sent from my iPhone using Tapatalk -
Pulled that up out of some old files. This is your OP here from his FB days. Sent from my iPhone using Tapatalk -
How do you even answer a question like that? Lol! Sent from my iPhone using Tapatalk
Yeah, I wasn't sure in the original description what he meant. Still don't as I don't recognize that piece. Sent from my iPhone using Tapatalk
You can route it wherever you want. It is just a vent and inconsequential. Most people just plug them though. The aftermarket covers don't even have them. Sent from my iPhone using Tapatalk
Are the voices in your head getting louder? Sent from my iPhone using Tapatalk
Yuck. Sent from my iPhone using Tapatalk
