Tedder
    25
Everything posted by Tedder
  1. Absolutely like new condition RDZ OOF Drag pipes One out each side Small bore / Small flange Used on asphalt only Less than 4 hours total run time on them *Ceramic coated* $375.00 shipped within the lower 48 Add $10.00 if Paypal
  2. Stinger $375.00 shipped I just got them but turns out they're big bore and I need small. I'll get my own pics for anyone interested but if your a Planet Sand member so you can see pictures the whole post of where I purchased them is in the for sale section. http://www.planetsand.com/forums/ubbthreads.php/topics/1040327#Post1040327
  3. Got a very nice set of Shearer one out each side small flange big bores for sale. PM me if interested.
  4. These guy's are absolutly right, Detonation will rattle the plugs loose. Been there done that with both my alcohol bikes. 99.99% of the time it's a lean condition. Fair warning - Fix it or you'll break it for sure.
  5. Assuming the process was done correctly it's still a little rich but remember the WOT run only tells you that the main curcuit is correct. If it were mine and it pulled hard from bottom to the top I'd probably drop one more jet and run it there for a while.
  6. LOL - Most of you guys are younger than my kids. I'm 52 from Northeastern Ohio.
  7. The pressure plate can be put on in a way that it doesn't drop down over the clutch pack. There is a punched mark on the inner clutch boss and an arrow mark on the pressure plate. Make sure you have them lined up correctly.
  8. $20.00 "gift" sent I almost sent you a pm before posting up in the wanted section! Thanks
  9. Like it say's - Looking for a bunch of GOOD stock clutch springs. Don't want to spend a ton of money but let me know what you have. Thanks
  10. Lots of opinions on the best way to tackle jetting. Heres my .02 Although I haven't done a plug chop in years I did when learning and would recommend it for any first timer with little or no tuning experience. Start by reading all the info you can find on the subject. Plenty of good info right here on the HQ. Once done you'll feel pretty comfortable with the whole process before even firing up the bike. Look for others with comparable setups and altitudes to get you in the ball park then do a few plug chops. Done correctly you can nail the mains pretty quick then work your way down through the other curcuits with "the seat of your pants" Good luck
  11. We use Digitrons on our asphalt bikes. Great tool but it's not something you throw on and use exclusively to tune your bike. Do that and I'll guarantee a crappy running bike or toasted motor. Search on this site about jetting recommendations from other members with similar setups to yours and on doing a proper plug chop.
  12. Thanks for clearing that up for me Brad - Those pics don't look anything like I remember. The additional material on the sides will be a nice improvement. Could one of the new units be purchased without the cutout in the grill area? Ted
  13. I have a single 19CC Pro Design dome if you can find someone else with one. LMK
  14. I'm sorry if you took my post as negative Brad because it wasn't ment that way at all. When you said you were coming out with a glass for those with stock frames I took it as a newly designed piece. A year or so ago I inquired about a "Barn Guys" front glass for asphalt bike and was sent some pics of one mounted on a stock frame. The nose looked to long on the stock frame IMO. Like it have been designed for an extended front end. Ted
  15. I'm not crazy about the way the current ones extend beyond the front OEM frame rails and as far as the closed grills concerned, heats not an issue for me, I'm looking for clean aerodynamics.
  16. Welcome to the HQ, I'll be watching for the new stock chassis hoods. Will you offer them with the solid glass grill area also?
  17. 4 brand new outer Wiseco Hot Rod Crank bearings. $55.00 shipped in the lower 48
  18. I'm in Northeast Ohio and our tracks are shutting down for the season. I'm looking for any 1/8 or 1/4 mile asphalt strips open this Sat 11/14.
  19. cbn70 Send me another pm if your still interested in these.
  20. 4 new OEM Banshee crankshaft bearings $60.00 shipped in the lower 48
  21. Try white lithium in a spray. The carrier dries in a few minutes and the rings stay in place pretty well.
  22. Like it say's - I'm only interested in them if they're in PERFECT condition.
  23. Brand new 40 tooth PBI aluminum rear sprocket for Honda ATC350X and ?? $15.00 shipped in the lower 48
