(2) - Wiseco WPR178 long rod kits
+5 (115mm)
Original boxes aren't the greatest but the kits are still in the factory sealed packages.
$120.00 shipped in the lower 48
Can supply pictures but I won't cut open the packages.
Wiseco Connecting Rod
Precision-trued to OEM specifications and factory assembled
Connecting rods are double-forged to maintain superior dimensional consistency through improved grain flow
Shot-peening eliminates residual stresses and smoothly blends the rod forging surfaces
Corrosion-resistant surface treatment
Top and bottom end rod bores case hardened to 58-62 RC to optimize bearing running surface
Crank pin bearing radial running clearance is optimized to ensure maximum performance
Precision honing ensures ultra-round bearing surface
Precision-engineered oiling slots maximize rod strength and bearing life
Double-drilled small ends provide the piston pin with extra lubrication and cooling, reducing distortion of top end due to thermal transfer from the piston
Silver-coated bronze phosphor thrust washers with dimpled design increase oil retention and reduce friction between rod and washer interface
Crank pin bearings are manufactured with the highest-quality hot-rolled steel -- case hardened to 58-62 RC
Caged needle roller bearings provide the highest possible RPM
Precision-machined crank webs
Crankshaft comes with top-end bearing
Connecting rod kits come complete with rod, crank pin, crank pin bearing, top-end bearing and thrust washers
