Downndirty, we carry all the parts you will need to fix your shifting woes. It is an easy fix as you just have to remove the clutch cover and basket to replace your bent shift shaft.
Give us a call and i will get you going by Labor day if needed!!!
Well with all that rain if Dan runs, at least the starting line (Burn out box, for Dan) will be wet for his John Force style burnouts. jk lol :yelrotflmao:
Jmadd, please call if you need any help on setup for alky...
Im not worried Dave as JT is MUCH heavier (bike and rider) and i liked to see him try different pipes. He is running very close to the same times even with all this against him. Apples to apples lets try it again and see the outcome. Shaynes bike runs good no doubt.
Sorry , our phone has been wide open throttle and pegged out all week, im human and can only do so much. Just give me a call or your # via pm and i will call you back. It is a very easy install.
Might give a call to some of the sight sponsors at the top of the page as they have them in stock, offer great deals, and help support this sight !!!! :wink:
Damn it Dave, its a destroked 660 (498) and i built it while in the hot tub. :yelrotflmao:
Hey you need to get your arse down to LS for the HQ ride, maybe you could leave your dogs boarded at the Vet as that is what we do sometimes.
Guys, its not that hard. Please call me if you need help.
First you set your idle with the sync tool and make sure they are the same (rpm that you like) from side to side.
2nd, You raise the rpm a bit so both carbs are for sure pulling up the slides a bit and adjust the cable pull on top of the carb caps so that the sync tool reads the same from side to side.
Double check everything and your done. wallah!
Stock carbs with Tors are hard to get perfect sometimes as all the mechanisms in the tors box dont seem consistent. If you have other carb tops or carbs call me. They work great!
Too many "will see" and "well, i liked too" . Cmon guys, there is at least 5-6 of you from Michigan area that if you all grouped together it wouldnt cost much at all. Badassbanshee's made the trip a few times and always had a great time. Would love to have you there and it will definetly be a fun trip with alot of racing/duning!
So the trip is first weekend of Oct. ???? Correct?
