trickedcarbine
    159
Everything posted by trickedcarbine
  1. And rule out the Toomey's right away.
  2. Are you referring to an idle screw kit like what comes with the TORS delete? Where are the air screws set at? It should idle back down when screwing them in. If that doesn't make much difference, you need to check for air leaks.
  3. Have you got to put a compression gauge on it to make sure it's not fried in one cylinder? Checked for air leaks?
  4. You mentioned spark plugs made a negative difference. Were they solid tip or thread on tip?
  5. Yes they should be able to be set up for use with the pump. Look in to having it done by someone who is familiar with converting carbs to alky use.
  6. From what I can find, the part number on there indicates a regular 35mm PWK. If they haven't been converted to pumper style, you will need to have that done or purchase different carbs.
  7. Keihin's typically jet happy between 1-3 turns out if they have the proper pilot in them.
  8. Possible they have a fuel pump on non pumper style carbs. It's more likely that it's just the float adjustment. Are both carbs spitting the same amount?
  9. 110 for sure. Double check all the clearances like squish.
  10. That dude looks like he's getting reamed out by that chick.
  11. I hesitated for years because I was scared to break stuff. However, there are lots of 10 mil motors being ridden reliably in several applications. And I'm glad I made the plunge.
  12. Even better, I got her to sign a document stating that if we are to seperate she is to transfer all ownership of any firearms I loaned her money for, to a third party who also signed the agreement. No idea how valid it would be in court, but she signed it in front of a notary and it's stamped.
  13. Sell the motor, sell the parts off the chassis, scrap the frame.
  14. Crank case is possibly not sealed between cases or clutch side seal. Pressurizing the trans case.
  15. My girlfriend has a great collection.
  16. Possible scenario. It is starving for fuel. You are sucking the bowls dry and they recover when you let off.
  17. AR's are cool, but I'm wanting to try an AK build this time around. Any body done one of the 80% kits with some hands on experience? Any major dos or don'ts? Just went through my buddy's AK, and I'm thinking I need one now.
  18. Yes, you can run a front caliper. It's a bit more tidy. Look at Tabata's build thread. There are a few photos.
  19. Are you still running an actual rear with a block off plate? Or have you switched to a stock front caliper for a cleaner look?
  20. Find some 35's to try. It'll let it really eat mid to top. If it's not snappy enough any more, then try 33's.
  21. I'll try to sneak out to the shed for photos for ya, but in all reality, you can look on cuervo's page on Facebook and see a ton of images.
