trickedcarbine
    159
Everything posted by trickedcarbine
  1. What front shocks and how is the camber, castor, and toe?
  2. Nice. Have you verified the nut on the ball joint clears the resivoir on compression?
  3. Those the shocks NastyRacing was selling?
  4. Pretty steep. I'd put it about 30lbs heavier on the front right if you have a set of scales.
  5. Not negative. The spread stuff never ran like it should have on motor. Now I think the spread stuff is helpful (ish) if you are going to run an ass load of spray, but even then, there doesn't seem to be much (If any) performance advantage. Velocity over volume still prevails 90% of the time. True sir.
  6. Genuine parts, no headaches with knockoff garbage.
  7. Some of the fastest fella's are cutting their springs.
  8. A little heat shrink tube has always been my go to on several different types of pipes.
  9. Fucking hate those people. It's the same in remodeling. Customer has you working on their clapped out shit, and when something else goes wrong, "It wasn't like that before". Sure cocksucker, sure....
  10. Set pick up gap on flywheel nubs. Clean coil ground. Un screw spark plug caps and trim wires off a CM. Fatter pilot jet if it's not a stock build. Verify pipes are clear. Make sure fuel is flowing through petcock.
  11. Anything Billit. Stay away from cast timing plates.
  12. In theory more balls spreads he weight out better. However, you then end up with smaller balls and higher static load. There was a few really cool article way back on it from Timkin and SKF. I'll see if I can find it.
  13. Duncan Racing was great till about 2000-2005ish and they were forced to move on in to other ventures. They have a few no name fella's running machines in there so there is no way it is the same quality they built their name on. Sorry you got burned, but this is exactly why people need to do research and check out forums.
  14. Fock that junk Who spread your bore?! So negative this morning...
  15. A few MM's of additional transfer can go a long way. Seems like guys are finally getting all the DMX's, Caracal's, Cougar's, and Scimitar's to run consistant. Like anything, if you just keep throwing time and money at it, it's bound to finally run. Lol
  16. Yes, the single cylinder stuff gets the advantage of massive transfers. The twins and triples only have so much room between the bores to cast, so there is less volume.
  17. Rockets on my ported 4mm with 35's were really great on anything but 1/2 mile courses. They made the torque, but when you go to wind it out on long straights they sign off a bit early when you really need over rev. As far as torque and HP gains, the CPI will be the happy medium.
