BLACKBANSHEE04
Contact Methods
  • MSN
    MAYOROFTHESOUTH
  • Website URL
    http://
  • ICQ
BLACKBANSHEE04's Achievements
  1. I heard that no jets come with the cpi pipes so what will be the best jet to run with a ported cylinder running pump gas
  2. Does anybody know where in south carolina i can get my cylinders ported
  3. If anybody on this forum is from south carolina i would like to know is there anywhere i can get my cylinders ported
  4. Can somebody tell once again what is the best top end pipes cpi high rev pipes or the toomey 5 an maybe procirut
  5. Can somebody tell do i have to cut my front fenders in order to use the cpi inframe pipes
  6. Is a sand dune drag port is made for only sand because i ride and race my banshee on the back roads
  7. What is the size of a 68mm piston because i heard that banshees tend to overheat when u bore .80 over
  8. My banshee is stock but i got plans because i want to dog a raptor and a ds650 but my first plans for my banshee is 1. buy some ported cylinders 2. pipes 3. bore 20 over 4. vitos super stock pistons 5. 15 teeth front sprocket 6. timing advance 7. better water pump 8. vforce reeds 9. head with mayber 20 or 21cc size domes for pump gas And my second plans is 1.4mm long rod stroker crank 2. bigger carbs 3. better radiator
  9. What kind of work does it take to fit a 7mm stroker crank in a banshee and i heard something about the crankcase have to work and i'm just wondering can a local yamaha dealership do the work
  10. Which pipes will give better top end with ported clyinders and i was wondering should i get cpi high rev or toomey 5 racing pipes. THANKS
  11. What i was trying to figure out that i seen a 4mm long and short rod stroker crank and i seen some pistons by vitos for the standard length rod that will give u 8hp mid to top and then if i use long rods will the wiesco long pistons give me any power like the superstock stock piston from vitos
  12. Which rod will give the most power with ported cylinders short or long rod
  13. I'm trying to look for the best reeds to buy that will give more horsepower then stock
