sheerider11
    107
  1. Start with the 390 and needle in the middle. That should run. But will be rich. The 270 or 80 will be your ticket. But you never know. Keep the 27.5.
  2. well if you are having a sponsor port it,you should buy everything from them all in one shot. Piecing together shit usually works out bad.
  3. This is who is porting your cylinders? Care to share what record this was?
  4. What about it. That's why the sprocket guard is for. Make sure you run a single sided tho. The dual just channels shit into it Sent from my SAMSUNG-SM-G890A using Tapatalk
  5. If you are from Virginia, surfrjag is close and builds a mean motor
  6. Much more information on the regular pwk vs the AS.
  7. Compression is just that. How soft are hard it is to compress. To hard it feels to hard and the shock doesn't work well. To soft and the bike just bottoms out and feels off. Rebound is the speed the shock "resets" to ride height. To slow it packs. Meaning it bottoms out and you basically have no shock. To fast and it starts to buck. Meaning it shoots back into position in a violent snap. That can send the bike launching forward or just bounce the front end around. But there's a lot more to it. Spring rates and ride height/preload there's high speed and low speed compression. Any more then that, is above what I know.
  8. If the sticker is 54known on that you get it! Is it brand fucking new? If it is, you get it!
  9. crap, there was a company that made custom neoprene covers. it's was expensive tho. Like 500 to get front and rear.
  10. I would run straight fuel and see how it responds
  11. Have you tried turning it down? I normally keep mine tight but in trails like that I have turned it down and been fine
  12. dunes trail street even drag. I won't own a bike without one. They make riding so much easier
  13. Hiem > ball joint Sent from my SAMSUNG-SM-G890A using Tapatalk
  14. Some of the best. Your's look stock width
  15. It's also 3 bolts. Slides right on. I want to see some one use it
