sheerider11
    107
  1. Sure go buy it. Seems like you already made up your mind on buying it.
  2. The second line is what makes me say pass. I wouldn't even bother with it at that point.
  3. Can I add this stuff and not change it for a really long time?
  4. Also make sure you are dropping your shifter all the way down with your toe. If you keep it up a tad, the claw won't grab the star. You may just need to move your shifter up a few notches
  5. Oh okay makes sense. I'll pass on the pegs. They will just end up on the shelf for now. Sent from my SAMSUNG-SM-G890A using Tapatalk
  6. There's literally 550 in probably just the porting. I can't believe this hasn't sold yet! A ready to run redline setup that had been proven. With new domes. Or wait 3-5 months or more now for the winter rebuilders and an extra 4-500 bucks.
  7. Sell me those pegs! For cheap! Also wtf is that big ass hose for?
  8. To haven't provided a single source of these cheap tools!! You keep saying it, but you haven't showed one yet.
  9. Pv you can "control" the power and when. Super sweet set up and I would run one in a second if I could. Block offs are just wfo exhaust.
  10. Pro mod like said Order a FAST bottom end rebuild. Whoever trues and welds that crank should check the bearings. You can upgrade them if you please. Maybe some straight cuts. How old are your wear items? Pressure plate,basket,hub,clutch plates, cable,shift shaft,shift forks? Pancake bearing? Water pump? Tans bearings? It can get tedious very quickly in there.it all depends how deep you want to go and you time and budget.
  11. Probably 155 55 to start. Needle I'm not sure about. What do they come with
  12. what kind of deposit do I get? I'm not going to just send you a few hundred worth of parts and not have any thing to cover my stuff
  13. http://www.bansheehq.com/forums/index.php?/topic/175499-jdss-redline-4mm-stock-cylinder/page-1 You would be a lot of money ahead
  14. Look like motowoz. I see a lot of 450 guys swearing by them. Saying there as good as the top brands
  15. He gave me 2 with one of my orders. I got lucky. Every order I usually ask, when he did I got 2
  16. so your not riding all goofy footed and your lever is in a normal spot.
  17. Here's DDQ again Sent from my SAMSUNG-SM-G890A using Tapatalk
  18. Yeah most likely. Start it and work the lever a bit
