sheerider11
    107
  1. I got through to Kevin fastest with emails. He is swamped with work I bet. He's not gonna dodge you cause of this. I'm sure He's delt with this multiple times.
  2. Haha, it's funny how that guys pictures has everyone scared. I run a vitos crank. Good so far.
  3. I get maxim. They always advertise shit that has nothing to do with anything but I'm sure some one sees it and they think " finally I found it" like stated it's exposure. It can never hurt. I'd say go for it.
  4. Sounds like your looking for that 4 stroke bottom end kind of pull.
  5. If you sit on the bike it will be on the left side under the gas tank a little towards the front.
  6. Disconnected from the carbs or the brain box?
  7. Sounds like your trying to compensate for a leak. Do a leak Down test.
  8. Congrats man, glad to hear everything went great.
  9. okay cool. I didn't think it would be that bad. Sorry for hijacking the thread OP.
  10. Since you had both 110 and 115, did you notice any difference between the 2? As far as wear on the jugs due to more side load?
  11. I got a vitos 4 mil. Even the 110 rod. I haven't had any problems yet. I've got a couple hard hours on it.
  12. I can't understand how it just doesn't float the reeds and make them useless.
  13. I have an idea. It got 30* warmer and you never mentioned changing your jetting. I could ask what pipes elevation porting and all that goods stuff and tell you what jets you should be about, but then you won't know why it works. So go to the jetting section and read up on jetting. See what you're at, where your elevation is, and see what you can get out of it.
  14. Shake the fly wheel. If you hear a rattle then its garage. That's the magnets inside breaking up. You had lock tite on the bolts and they still backed out?
  15. Need one or the other. Thanks.
  16. I feel like if I don't buy those front shocks, I'm passing up way to good of a deal. What's the length?
  17. Yeah, if you ask anyone here you can get a list of what people use.
  18. That's something you should fix the first time it happens. But do they completely lock up, or just start to drag?
  19. Haha, you going to see the difference.
  20. So my girl friend got a banshee and now its time to sell the kx85. Its clean, and is all stock. Has low hours and was not ridden hard at all. Meticulously cleaned. It's1200 firm. Pm or text me for more info, 7324064991.
  21. Just zip tie cardboard to the frame then
  22. So you can change a crank, but you have no idea what to do to bore the cylinders?
  23. I told you bore it. Send it to a shop, they do it. Then they set you up with the exact pistons you need. It's a very simple common process. That's the right way to do it. The other may look fine, but you can't tell if it's egg shaped or wore to the limit. Do it right, bore it. Trade in the wrong pistons you bought.
