450 plus shipping and you can take them both.
I don't know if anyone runs ishock but these are heavy duty arms. Both ball joints are tight, dosent use shitty heims. Grease zerks at all 3 mounting points.
Most likely. On the back plate grind off the rivots and punch them out. But, I would pick up a billet basket and be done with it. Cause if your needing cushions, it's prob all grooved up
I have a ishock set of +2+1 arms with works triple rates.
These are some serious heavy duty arms. Check out there website there the phantom arms. Both upper and lower ball joints and no heims. Sealed sleeves with a grease fittings at all 3 points. Serious tie rods too.
The triple rates are starting to leak. I bought them from here and used them. They still eat up the bumps awesome tho. But do need a rebuild soon.
I will get better pics when I get home.
Asking 450 plus shipping
That's the best pic I have with the stock front shocks.
I have a hjr mx/ hardcore 4 mil that I would trade for any other 4 mil port pump gas domes
We'd go straight across
Cylinders
Pistons
Domes
Just seeing what's out there if anyone is interested. Just no drag port
Keep the FMF and carbs for now, pay to get it ported and domes set up. Believe me, I did it the same way you are. Huge mistake. Wasted money. Bigger carbs will make it worse on a stock port
Gas stations by me won't fill up fuel jugs if they aren't approved colors. Red for gasoline, blue for diesel. I'm not sure about yellow. But clear and off colors are a no
I need the front brake line, power valve assembly, kicker gear and lever, intake. If you have anything let me know ASAP. The cylinder is going out to be replated so the power valve and kicker assembly are at the top of my list to get the motor together
