X2 but before we jump in and pull the motor, pull the pressure plate off. ( 6 10mm bolts hold it on) take them out. There will be springs behind them. Pull that plate off. Now take a magnet on a stick ( usually at any autozone next to the register) and stick it into the middle if the shaft that was right behind the pressure plate. (There was a screw with a nut on the front on the pressure plate that went into that shaft. Can't miss it)If your lucky, a ball bearing will come out. Maybe "welded" to a shaft. As long as they both come out your good. If you can't get it out, your in it for the long run.
Search around on here, there is a service manual. I believe that should show you how to remove everything.
If you have any questions just ask. I'm assuming you know the basics.
