sheerider11
    107
  1. I just laid a set of domes in a coolhead. They sit up about .006"-.007" from the shell. Will the oring make up that space? Or will the squish down and make it flush? It's constant all across and between the domes. These are the best I could get the picture. But
  2. If it's cheap and the rims are in good shape them it may be worth it just for the rims
  3. Get paddles. Once you go to the sand you won't go back
  4. I have an already powder acted clutch cover. Can you make mine like the quick change cover?
  5. Ha! I remember that. He claimed he was the best and knew everything. Just came in said these pistons were the shit and everyone needs them. Well he was ahead of the curve. He might have been somebody to have had them so early.
  6. It's a wiseco piston. What more feedback do you need? It just a specific setup for a 4 mil with shit in the correct place. People never really asked about blaster pistons. They just ran them
  7. Sounds like it ran out of gas. May have leaned it out and burned it down. But if I were you I'd take it for a second opinion.
  8. Got ya. Yeah there a good thing to have around. Sent from my iPhone using Tapatalk
  9. A thread file, flip the castle nut around. If it's in good shape it'll act like a chase
  10. just drag it around till it starts. Fuck all the other shit.
  11. Is it a blind hole or go through the case?
  12. Some one made one under the seat not to long ago. Never saw much more of it after the first post. I'll see if I can find it.
  13. That came out wrong, I quoted that. Those are a members tanks. Bigred350x. Those are his, I've never had one. Maybe someone here can get in contact with him as he hasn't been on in a while.
  14. I used a 3gal spun aluminum tank off ebay and took a 6-pack rack and cut the bottom rails off the rack and welded on new mounting brackets for the tank onto the 6-pack rack. I use a shutoff valve under the tank, then a filter then it feeds into the back of the front tank. I run my dune bike on methanol and get more mileage out of my two tanks than the stock banshees do on gas with just the front tank. I aldo did the same thing for the tank on my R6 raptor. The factor air box and carbs sit under the front plastics so I moved the tank to the rear just like my dune banshee.
  15. No. That's plenty to start. Did you do a leak down? Are the reeds good? Are the pipes plugged? Correct spark plugs?
  16. Yeah put the gauge on it. But you don't have to make a new topic every time. You can just go back to your old one and continue there. It'll be easier for people to help you diagnose.
  17. Also take these slp pipes that everyone has been raving about
  18. Hell yeah thanks. If not we wouldn't be able to do the stupid shit we do now.
  19. Unplug box and switch from throttle. Unplug parking brake as well
