sheerider11
    107
  1. Tyler and beef must be proud
  2. sounds more like you don't know what youre doing then the quad being a piece of shit. Its a machine, it can be fixed.
  3. They'll never seal. They weren't ment to. Arlen at LED (LRD) will tell you to use red rtv
  4. Red rtv. I personally didn't like my lrd adjustable pipes tho. Adjustment made no difference and weren't much different then fmf power delivery. Nastyracing on here swears up and done that there the best pipe ever made
  5. Soak the studs in PB blaster. It'd be a whole lot easier to have the cylinders off IMO. Use heat. Don't force them out. I've always double nutted them. The 2 long studs are the front 2 studs. Use Vaseline/Chapstick/assembly lube to hold o rings in place.
  6. Well I'm sure it's not your stamped or unstamped CPI. Start your own thread, you'll get better results
  7. I have unstamped. I got them for 300.00 in decent condition.
  8. Go to the sponsor page. I've never used Facebook and I get parts all the time just fine by calling them.
  9. Hmmm. Where are you located? You should do a leak down test. I'd say you developed an air leak. Try to avoid a dealer. There's a few things you can do to keep the engine from blowing. Good mix, good fuel, good jetting. You can do a leak down every few months if you want and a compression test. That's about it. After that, shit happens. Use quality parts to do the rebuild. It may be cheaper for you to buy a complete engine and get it shipped tho depending on where you are.
  10. So do you run a boost bottle? I had a PD. I'll see if I can find it. It's scored up from getting sloppy and the shaft wearing. Put oem. No issue. Mull finally made a billet with the correct shaft that doesn't wear
  11. As far as that I don't know. But 99% of his info was the same as anyone else. I don't know windy from a hole in the wall. But he usually provided good info and was always willing to help. Sent from my iPhone using Tapatalk
  12. As much as people like to point fingers at windy, he was usually right. He was smart and knew what he was talking about.
  13. Was 400 shipped back to me. Sent from my iPhone using Tapatalk
  14. Sent from my iPhone using Tapatalk
  15. I didn't pay tax. I paid for the rebuild and new spring. Sent from my iPhone using Tapatalk
  16. Well I got it back today. Didn't get a phone call or anything. Just shipped it back to me. The engraving on the shock is my setup but I expected them to at least contact me and let me know the cost or where it was at.
  17. It's a scam. That same ad has been here in jersey, florida and PA
  18. Chariot Noss and the sleeper heads I believe there's a few more tho.
  19. PM me if you want to swing by. I'd never trust a dealer. They haven't seen these bikes since 06. If you feel the need to get crazy luckily a guy right over the bridge from you does killer work as well.
