sheerider11
    107
  1. ||||||||| straight cut ////////// helical cut. Most stock to mild run helical. Just look at the basket and primary
  2. Get them from fast. 10% off
  3. Cyber Monday bump!!! I'll throw in stickers and shit
  4. Mechanic- just pry shit till it fees up. Good to go. NPF.
  5. that's how jets are drilled. Doesn't matter what carb.Drilling holes bigger may help. But so will covering half the filter to restrict air flow. Doesn't make it right.
  6. It's more then just the diameter of the hole. Some have a step that is drilled deeper or they taper. There's more to it then an orifice in a piece of brass
  7. That the parts washer juice isn't good anymore.
  8. Those cylinders are old if there LRD. Hasnt gone by that name in a while
  9. I will not run stainless bolts for suspension. I will not pay to chrome them. Natural will be fine
  10. Just get the 4s. There worth it. Stock to built they'll help.
  11. That fire ball is tits. Those are one of the only 3 I would run. I'm sure if you call fireball direct aND order EVERYTHING at once I'm sure they would hook you up
  12. Here's better pics now that I'm finally off. You can see the bumpers have no oil and it has the updated seal heads Sent from my SAMSUNG-SM-G890A using Tapatalk
  13. Junk front end. I'll buy it off you for $450
  14. Did you check the a arm bushings? Or just tighten them?
  15. This. I only have my stingers wrapped and they look like hell
  16. I got them back in may. I have maybe 8 rides on them. 200 lbs set up Sent from my SAMSUNG-SM-G890A using Tapatalk
  17. Sent from my SAMSUNG-SM-G890A using Tapatalk
  18. The fastest 400cc banshee ever built I assume.
  19. I run my bike out of fuel all the time. It just dies. I've never had it run away or lean hang. Like stated, you should be checking else where. Use photo bucket or Tapatalk to upload pics.
  20. I wouldn't take any elka shocks. No works. No cash. I need shocks still. Trade only.
  21. I don't know. I see a lot of people running fox shocks. I had a set of first gens. I liked them.
