BluBanshee98
About BluBanshee98
  • Birthday 10/29/1980
Contact Methods
  • Website URL
    http://
  • ICQ
  • Yahoo
    Deere2500HD
    Buckeye, AZ
    07 Trick Racing Products LT Sandcar 97 Shee Restored Paint PC Pipes and Pods
BluBanshee98's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Yamabond for the case halves...you can pick up permatex moto seal at most major auto parts stores...it's pretty much the same thing! Gray runny but dries pliable.
  2. http://www.bansheehq.com/forums/index.php?/topic/110585-Leakdown Tester There's the link...I just got done making one...way easy. That cylinder is more than likely sucking air! What do your plugs look like?
  3. Look at the pinned up top for the leakdown test! It tells how to build one for cheap and how to use it. Now for the reed breaking...make sure the window on the piston skirt can be seen through the intake. I'm sure it sounds far fetched but ya never no. From what I read up top you just removed the head to make sure it was .20 over! Also if the carbs are not in sync that will wreak havoc!
  4. I have a 1994 with a harness that has been cut and spliced. Had a cdi go bad so I ordered a new CDI for a 94 and my harness side is the 2 square 4 prong connections. If someone has just the connectors I could properly splice in or a whole cut up harness please let me know. I was just gonna get a different cdi but seeing as its a 94 i'd prefer to just make the connections correct. Thanks
  5. Crankworks 10mm Banshee Crank Heres the deal...I bought it from a local guy with the intentions of building a drag bike but things have changed. He said water some how got into the cylinder and when they tore it down they found it in its current condition. Everything still seems tight well within tolerance. I did take this down to crankworks in Tempe for an estimate and worst case scenario I would be looking at $550 and they said they doubted that but didn't want me to be blindsided. I asked what it would cost to buy this crank new....$1200. I'm asking $300 or trade for long travel buggy parts. Thanks Josh
  6. 2000 Chevrolet 3500 5.7L Engine 1 Ton Long Bed 4.10 gears 93000 miles 4 Wheel Drive 17x9 KMC Hoss Wheels in Black 36"x13.5x17 Super Swamper IROK Radials 6" Superlift Power Windows/Locks Title in Hand $8500 cash Josh 702-767-0695
  7. Found a Rail I want $8500 2006 Yamaha Rhino 686 kit Stage 2 Cam Ported and Polished Dynatek CDI K&N Clamp On Filter with Billet Adapter KMS Siphon Break KMS Exhaust Header Billet 2" Exhaust Tip New Unleashed UTV Machined Sheave New Greaseless Rollers New OEM Belt New Orange Secondary Spring ESE +6" Long Travel Kit Radflo 2.0 Dual Rate Remote Rezi Coil Over's Gorilla Axles Aftermarket Spindles All A-Arm Pockets Gusseted B&A Motorsports Black with Blue Metal Flake Cage and Baja Style Rear Bumper tabbed for Lightbar B&A Bed Delete B&A Front Bumper and Skid Plate Full Doors Complete Firewall around Cage Full Roof with LED chase Light and Brake Lights Trail Logic Front and Rear Aluminum Skid Plates Autometer Fuel, Volt, & Temp Gauges K-4 LED Switches Vision X HID Stock Replacements Stiff Whip Flag With LED Light JAZ 8 Gallon Fuel Cell PRP Suspension Seats Crow 4 points ITP Type 7 Black wheels 27" ITP XTR Desert Tires I have a few other things I will throw in for an additional price! There is nothing wrong with this machine. Priced so I can get this buggy. My loss is your gain! Gimme a call! More pics if needed let me know! Josh 702-767-0695
  8. Mikuni VM28 and bored to 30mm. Bike is a 94 all stock internals with FMFs and some K&N pod filters compression is at 120psi on both. I have been working and researching trying to get the jetting figured out. No luck. Top end is great but the bottom end and midrange hardly exists. Warm weather makes it act up. I just changed the pilot jets to 30 and I can't even back out the air/fuel screw more than half turn or it will die. The stock carbs had 25 pilots and it ripped so I figured for the bigger carb a 27.5 or 30 would work. Nope same problem. This thing had 50 pilots in it originally and still half turn out on the air/fuel screw was all I could get. Actually seemed to run better with the 50 pilots but had no mid range at all with wet plugs. I have changed needle positions still with no luck. The only thing I think it could be is the "jet valve" or the upper portion that the needle rides in may be an issue. Any input is greatly appreciated. I am not too far from taking it to the local dyno and let them deal with it. Thanks
  9. Try stepping up your main...sounds a bit lean on the main and if your plug is light that would also indicate the same.
