NO, that would not be accurate. Stroking a crank, alters timing slightly due to the rod angle delta but change in minimal. Timing is relative to clocking or indexing of the flywheel relative to TDC. What does change is piston velocity and that is more relative for timing adjustments. The faster you compress the air fuel (piston velocity), the more volatile the mixture is, thus requires less timing to achieve max cylinder pressure at 20* ATDC.
Head design, fuel, AFR, ambient air temp, etc, all will have an effect on what optimal timing should be. 165psi does not mean much to me in terms of engine dynamics. head design, squish clearance, CCR, and UCCR are much more relative for deciding what fuel is required.
Hope that helps.
Brandon
