racer
racer last won the day on August 13 2019
racer had the most liked content!
About racer
  • Birthday 01/12/1986
Contact Methods
  • AIM
    cole2534
  • Website URL
    http://www.dunedevilinc.com
  • ICQ
    Stillwater
  • Interests
    my rides
    '96 - it runs for now
racer's Achievements
HQ Commander In Chief
HQ Commander In Chief (5/5)
3
  1. YFZ450 shocks and a reworked rear would offer a pretty cost effective benefit.
  2. Welcome to 2004. If you're lucky you can sell your house now before the market shits on your face.
  3. Climbanyhill is correct, BJ's require less maintenance, and are quieter. However, this does not mean that they cannot fail like the above picture. The only way to prevent that would be to- 1) place the heim in double shear, capturing it. 2) using a safety washer over the head of the bolt. The benefits of a heim over a BJ come in, to me, these three areas- 1) double shear possiblities 2) off the shelf replaceable, since you're just using a bolt there are no tapers to match 3) more articulation when used in combination with a hi-mis spacer Uniballs are tougher heims. They, unlike the other two, require a welded-in cup, so no adjustments there. On the flip side, the cup is reusable, you only replace the bearing itself.
  4. A new spring would be the right choice. If you can find the spring rates available, do some math, you might have the right setup for it to work.
  5. Also, you could patch the hole and then blow out the dent. It requires a little air pressure and some heat.
  6. Pull the hose off the 'tee', aim it towards not you. Open petcock to 'res'. PS, a shot of air in the vent line will decrease your drain time.
  7. Just need a TIG, wonder why no one would do it?
  8. You're saying that when you start it, the tires turn in a direction other than forward? Knowing the starter, I don't think that's possible.
  9. So you're after an electronic cutting break? Sweet.
  10. Well, his name does include UAE . . .
  11. What's the point of this, corrosion issues?
  12. Not a bad idea. I used to do mine every winter, not so much anymore.
