jaysea1
Contact Methods
  • Website URL
    http://
  • ICQ
    Phoenix AZ
  • Interests
    Fast riding and powerlifting.
    04 red/white, T-5's, twin K&N's no air box...more mods to come.
jaysea1's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Can't we all just get along? When I get my TATUM car, I'll take you for a ride in it :baseball_bat:
  2. Thats a perfect description...I'm originally from SD, so I know what your'e talkin about. FLATBILLERS
  3. TATUM...built here in AZ, very pricey though...like bansh88 said CA to AZ are the best builders. Those things are awesome...wish I could get one(I won't take a second out on the house for it) Bansh88...what's a flat biller?
  4. Use a drill press. level, and secure the carb on the table of the drill press, lube with wd40 or all purpose oil while drilling and most importantly tapping(3 turns in then back out the tap clean threads, relube etc.) Shave the bosses level, (with a mill file)then take a little more off(just a little) so the idle screw makes good contact with the slide and lifts it up. Follow the directions in the kit carefully, and make all your adjustments after installation(sync the carbs, set the idle) Also after drilling and tapping wash the carbs out and blow em out with compressed air. If you need directions, go to Toomey's web site under tech installations, idle kit.
  5. As previously stated, RMATV has a warranty on these axles. I bought one, and ride in the dunes all the time. Fit and finish is good, install was easy(directions are ok)...this axle is also for the raptor and blaster, so there is an extra spacer that you will not use.It comes with 4 little spacers, that go on the ends( 1 or 2 per side, depending on the desired width) And then There are two large spacers hollowed out on one side(to house the cir clips)...only use the one on the brake hub side, the axle nut houses the c clip on the sprocket side. So far so good, I don't get 20 feet of air, so I don't know the limits of this axle, but for hard duning and draggin up the hill it works great.200$
  6. Very good point...half of these "Americans" refuse to lower their standards and work non skilled jobs. Hey, go to school, learn a trade... get off your lazy ass and do something or don't complain about working at Walmart. These people blame the illegals and everyone else for their stupidity. I also believe the borders should be closed.
  7. Sorry, I'll have to finally get to it, It looks pretty sharp though, kinda like the Duncan model. It's polished aluminum. You from hawaii? I was born at Trippler hospital on Honalulu
  8. I paid about 70 or 80 dollars for that Tag bumper...very nice looking bumper, had to tweak it a little to mount up though.
  9. Also as suggested, use a tape measurer, and measure from inside edge to inside edge on the front side of the tires, and then do the same for the rear side of the front tires. The front side should be 1/4" to 1/2" less than the rear measurement. Make sure to measure on the same plane of the tires. To adjust, turn the tie rods in or out, to move the toe in or out. Just loosen up those nuts, then turn the tierods. Make sure to make the same amount of turns on each tie rod for best adjustment.
  10. I set mine 1/4"(1/8" of an inch on each side) Helps stability at higher speeds.
  11. I saw that as well...cool stuff Thats the one with the shootout between the new raptor and the new yfz. How was that hill?
