87sheerips
HQ Site Sponsor!
    100
Everything posted by 87sheerips
  1. Pic of pin on the swingarm that holds the brake stay and prevents it from spinning round and round.... Like hopped up said.... There is slop there and you probly need the bushing. If you get me dimensions I can machine you a bushing to your specifications and we can get it tightened up... I would just run it for now, ain't gonna hurt anything being a bit sloppy. That what I tell my wife on the weekends too.
  2. I have done it, broke retention clip, used RTV and have been fine. For the price, buy a used one from eBay. I have never had a bad coil in 15 years of fiddling with these machines.
  3. 1. Swap CDI with known working unit. 2. Ohm stator 3. Set pickup gap 4. Make sure ground wire (in the back near CDI and voltage regulator) has a clean, bare metal surface that it is secured to. 5. Order a new harness from us to rule out all the BS. http://www.jdscustoms.com/product/oem-length-drag-cut-wire-harness/
  4. Yep Namura just has very specific bore sizes As seen here http://www.jdscustoms.com/product/namura-banshee-piston-top-end-kit/
  5. Ditch stock garbage and upgrade to 28 or 33pwk http://www.jdscustoms.com/product/33mm-keihin-carburetor-pair/
  6. Compression test I would imagine will tell us a lot. I bet it's low.
  7. Ditch the stock carbs for some 28pwks. You use proper torque and gaskets while assembling this thing? If you did it right and took your time I doubt air leak. Pickup coil you sure is ok? I can get you a new one. I wadded mine up last year and caused my bike to run on one cyl. http://www.jdscustoms.com/product/yamaha-banshee-stator-trigger-coil-ricks-electric/
  8. I have one in my barn. Such an awesome machine. BUMP! BHQ deal only!
  9. Yes can make anything you want if u want a modified one. This is about 14 inches from the front of the forward tabs to the beginning of the seat back Thanks!
  10. $60 shipped Steel or aluminum. http://www.jdscustoms.com/product/yamaha-banshee-lightweight-seat-pan-kit/ .048" steel is just over 2lbs .080" alum is just over 1lb Comes with grommets installed and stainless hardware
  11. $100 shipped Steel or aluminum. http://www.jdscustoms.com/product/yamaha-banshee-lightweight-seat-pan-kit/ .048" steel is just over 2lbs .080" alum is just over 1lb Comes with grommets installed and stainless hardware
  12. $25 shipped $40 world Gift PayPal with shipping address to jdubswmu@yahoo.com CDI: stock location Voltage regulator: stock location Lights/kill switch: stock location/stock plugs Headlights: stock location Key: hide a key location behind has tank/under seat
  13. These RB fenders are light! Seem to be lighter than my fast fibers from a few years ago... And have to be lighter than stock for sure! They fit like a glove and super easy to install. 4 quick bolts and the front is off... Granted you have to remove the bar clamp and turn bars 90 degrees but it's no big deal. Been running fiberglass since 2009 and have had great luck with them and they are kinda close to the OEM lines which is the only plastic to run IMO
  14. Thanks bud.. More JDS stuff to come on this bike.
  15. Don't have the means to make the covers. They are complex and will require a lot of machining. Chariot would be better to request that
  16. No time to work on the heel guards. Rear fender brackets are an idea! Too bad I don't have a normal banshee to work with....
  17. Pics don't give it justice. I do plan on getting some retro banshee graphics in black for the rears.... JDS customs for the front sides
