Tim C
About Tim C
  • Birthday 03/15/1974
Contact Methods
  • Website URL
    http://
  • ICQ
    Miramichi, New Brunswick, Canada
    '94 Banshee Cub Cylinders CPI pipes Vito's 30mm Dial-A-Jet carbs V-Force reeds Elka shocks Pro Design Coolhead and intake manifolds Durablue axle OMF beadlocks & IRazr tires IMS bumper Trail Tech Lights Cascade grill etc,etc...
Recent Profile Visitors
1,982 profile views
Tim C's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. I am interestested in how you got your silencers mounted in the middle with the drag pipes. looks awasome!
  2. Hopefully it's better then the other Polaris 4x4's because they are junk. They are fast and smooth but they are broke all the time.
  3. Did he lube up the bearings when putting them in because if they were dry it wouldn't take long to junk them on start up
  4. If the Raptor is basically stock you should have no trouble beating it with the mods you ordered
  5. I live in Miramichi New Brunswick......Silver lake is a little too far for me to go this year - but I hope to in future
  6. Like olmick said don't expect a big difference in power if any between the DG's and the FMF's. If you go with the Gnarlys you will probably lose some topspeed because they're a midrange pipe but you will definitly gain on the bottom end. The Fatty's will have about the same topend as the DG's and is a very good all around pipe similar to Toomey pipes. If your set on FMF pipes I would go with the Fattys unless your going to MX the bike want bottom end and not concerned with the top end power.
  7. The manifolds for the V-Force reeds don't have the tab in them - your's isn't for V-Force reeds. Can you remove the tab somehow
  8. I made a couple of brackets to mount it and connected the wires. My Banshee is a 1994 so it doesn't have a brake light The R6 light has 3 wires so if you have a brake light you'd hook up all three but without a brake light you only hook up 2 wires. It's a LED light so they say they draw less power then I regular light but I don't know for sure but I haven't had any problems with it
  9. Here's a couple pictures of the R6 tail light
  10. I put a R6 tail light on mine last year - PM me if you want me to send you a picture
  11. Put one in for my intake manifold bolts and worked great. Had the manifold off and on a couple times after and had no problems.
  12. One Industries make kits for alot of different companies. Try Alba Action or K&K they might have what your looking for Links: http://www.albaaction.com/ http://www.kandkatv.com/
  13. I bought a Miller 175 MIG and I love it - It works great, easy to make nice beads and it will weld up to 1/4" thick metal with 1 pass so very seldom would I (or most other hobbiest) ever weld anything thicker then that. All the square tubing for my utility trailer was only 1/8" thick. I never use my stick welder anymore because they are alot slower to weld with and a pain in the ass to use compared to a good MIG.
  14. A good fab/machine shop should be able to do that for you no problem
  15. 65mm Cub, welded crank (w/RZ bearing), CPI pipes, 30mm Dial-A-Jet carbs, VForce reeds, Coolhead, PD intake manifold, lightened flywheel, Barnett clutch, Vortex basket, Durablue +4 axle, Elka front shocks, OMF beadlocks etc. etc. Too much money into it for the little bit of time I have to drive it
