Master of Faster
    Mid-Michigan
Recent Profile Visitors
1,455 profile views
Master of Faster's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. I have a set of nice small bore CPI's, looking for a set of big bores if you're interested in a trade.
  2. Thanks for the interest slopoke but I'm looking to keep the set together, they seem to be easier to sell that way. If someone ends up wanting just the pipes I will let you know. And Joe, thanks for the heads up but just looking to off these for some $$$. :thumbsup:
  3. I have a set of Toomey T5's that were bought brand new last summer, decided to build a bigger motor and upgraded to CPI's at the same time. Pipes are in awesome condition, no dissapointments. Asking $350.00 + shipping for the pipes/silencers. Also have a set of the Toomey clip in spark arrestors, $100 + shipping.
  4. The OKO's love to drain the bowls on a decent WOT run, the fuel inlet and needle setup doesn't flow enough in stock form to feed a strong motor. Make sure that your fuel lines are nice and even to each carb, and then cross drill the boss that the needle slides in. These holes will allow more fuel to flow into the bowl when the needle is down but the needle will still seal as long as you don't knick the seat surface when drilling. Drill through like in the picture and then drill another set at 90* to these two, you should end up with four extra holes total in the each carb. No more breaking up/going flat at WOT. We've done this on a couple strong 4mm motors in the past and it has solved the problem completely :thumbsup:
  5. I'm assuming this is supposed to be a pump gas motor? Seems a little tight to me, throw a second head gasket in there and that should put ya about where you need to be. It will lower the compression slightly which would be good if you're running 93. At 165 psi on the gauge with a ported top end I would be worried about detonation on pump fuel.
  6. I'm trying to find someone who can get me 6.0 slides for my 35 pwks. My carbs were setup for alcohol and have 4.5 slides in them now and I'm having a very hard time getting the bottom end leaned out enough to work with gas. The places around me are telling me they can't get them. Does anybody know who has these things or can at least order them for me? Thanks guys
  7. Can anybody tell me what the stock dump tube size should be on a 35mm PWK airstryker? I bought a set to run on gas but I'm thinking they may have been drilled for alky. Thanks guys
  8. Pipes and polished silencers sold. Second set of Turbine Cores still available.
  9. $275 is for the pipes and the one set of silencers that are pictured with the pipes. The second set of silencers are older/larger and I'm asking $50 for those.
  10. Here's a couple pictures. Pipes look nice, have a little spotty surface rust on the back side that looks like it would clean right off with a little polish, typical bluing near cylinders. No visibile defects when mounted. The right side silencer did have a ding in the end cap that was pushed out that I forgot about, you can see where it was fixed if you look at it. Here's the other silencers. You can see in the pic where the left side tube was welded near the mounting tab, still fits and sounds good. No leaks. The right side has a small rock ding in the bottom. There is also some rust inside the end caps. These aren't like new, but still function great and look just fine.
  11. I've got a very nice set of FMF Fatty pipes and turbine core 2 silencers (spark arrested) for sale. The silencers are fully polished and look/sound excellent. You can still read the forestry approved stamp on the side as well. Asking $275 + shipping, will take Paypal or money order. Also have a set of the older style (larger) turbine core silencers for sale. The left side tube has been welded but isn't noticeable and has been run for a long time like that without issues. These are clean but not polished like the first set. $50+ shipping, cheaper than sparkys. I'll post pictures later this afternoon.
  12. I'm looking for a set of 35mm PWK's, PM me here or email to drbutter@svsu.edu Thanks guys
  13. Looking for a complete set of inframe smallbore CPI's. Must be chrome and in nice shape. PM me here or email at drbutter@svsu.edu Thanks guys, Doug
