alcoholbanshee
    30
Everything posted by alcoholbanshee
  1. Gotta be real persistent. He won't sell you one until he realizes how serious that you are. Don't let him fool you, he has them.
  2. A tank of fuel should do......
  3. Maybe your best comment ever....... credit where credit due
  4. How much for the BHL??
  5. Do a search on how to do squish. It is super easy to do and all you will need is a couple pieces of solder and a good measuring device. I dont feel like typing a small novel on a phone......sorry lazy
  6. Yup, I wanna know what the squish is and exactly what octane fuel you were using when it was backing plugs out. My guess is going to be poorly designed domes. I am assuming these are trinity domes, and that does not give me the warm fuzzies.
  7. Snap a pic focusing on the right side of the flywheel, just above the pick up coil.
  8. I would run at least 93 octane with that compression. Do you know what your timing is. That would be an important number to know
  9. Not enough fuel, not high enough octane fuel, too much timing, poor dome design among others...
  10. There are many variations of viton. Yours is too soft I am guessing.
  11. Claude + goat  = match made in heaven
    1. SKEETER
      SKEETER
      Claude+goat= animal abuse
    2. alcoholbanshee
      alcoholbanshee
      Claude + goat = love at first Baaaaa
    3. ClaudeMachining
  12. The part you mentioned will just be 4play
  13. Lick .... Hole
  14. I don't know. That "por design" head will hold you back I think.
  15. Are these off the shelf oring? As in are you guying at Zatkoff are someplace similar? Is it possible you need an oring of a different durometer? That is going to be my best guess is you need a harder oring. Also it is important if this is not a mono block to torque the head before torqueing the base gasket.
  16. bore x bore x stroke x .0007854 x # of cylinders = CCs
  17. What you got is good. But I would call Safarian at sandtoyz and see what he says for paddle count
  18. Not so much on the good advice. He is overthinking the hell out of it. Do a little research on snowmobile fuel pump systems. All you need is a port in one of your intakes for the pulse, a fuel pump ( most any 2 cylinder snomo pump will work) and the proper needle/seat assemblies in your carbs. Its that simple.
  19. For an 8" wheel you want 21" tire. But the question is what you do with the bike. Hill climbing and playing around you have the better tire already. If you drag race a lot then you want the 8" rim tire.
  20. NGAF...............................that is all
  21. I got a 20hp Craftsman lawn tractor with a ngk plug and a k&n filter bitch..... You wanna go
  22. Skeet never owned a banshee...... Just a tricked out atc70. Complete with tassles on the handlebars.
  23. You should probably retain a lawyer, this could get ugly
